[mapserver-users] RE: mapserver-users Digest, Vol 12, Issue 73
Chad Clabaugh
cclabaugh at centwire.com
Tue Jan 20 09:28:35 EST 2009
Am I not specifying my projection by using "init=epsg:4326" within the
PROJECTION BLOCK???? I have tried as many different projections as I can
find. Including 4326, 900913, 3785, and the following block...
PROJECTION
"proj=merc"
"a=6378137"
"b=6378137"
"lat_ts=0.0"
"lon_0=0.0"
"x_0=0.0"
"y_0=0"
"k=1.0"
"units=m"
"nadgrids=@null"
"wktext"
"no_defs"
END
...which didn't work for me.
Message: 3
Date: Mon, 19 Jan 2009 20:16:28 -0800
Subject: Re: [mapserver-users] google tiles
To: "Chad Clabaugh" <cclabaugh at centwire.com>
Cc: mapserver-users at lists.osgeo.org
Message-ID:
<30fe546d0901192016u1ad26e6fy7ec54e13da416c18 at mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1
You need to specify the PROJECTION of your LAYER.
P.
On Mon, Jan 19, 2009 at 6:50 AM, Chad Clabaugh <cclabaugh at centwire.com>
wrote:
> Greetings,
> I have been trying to generate google tiles from shapefiles using
> mapserver. I have been able to successfully generate maps by calling the
> url
http://0.0.0.0/cgi-bin/mapserv?map=/srv/www/htdocs/mapserver/coverage.map&mo
de=map
> . but when I attempt to use the url
http://172.18.154.186/cgi-bin/mapserv?map=/srv/www/htdocs/mapserver/coverage
.map&mode=tile&tile=4+6+4
> I receive only empty images, regardless of tile specified.
> Thanks for any help!
> MAP
> NAME COVERAGE
> STATUS ON
> SIZE 1400 900
> EXTENT 639000.000000 4535300.000000 689900.000000 4582600.000000
> UNITS METERS
> SHAPEPATH "shapefiles"
> IMAGECOLOR 220 220 220
> IMAGETYPE PNG
> PROJECTION
> "init=epsg:4326"
> END
> LAYER
> NAME CoverageMap
> TYPE POLYGON
> STATUS DEFAULT
> DATA notforchad
> CLASS
> STYLE
> OUTLINECOLOR 255 128 128
> COLOR 225 0 0
> END
> END
> END
> END
> Chad Clabaugh
> Technical Support, Engineering
> Office: 260.760.6398
> Mobile: 260.466.8861
