[mapserver-users] optimal path between two points.
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Jan 20 10:38:06 EST 2009
Valeria,
You should really look at the example provided with:
http://pgrouting.postlbs.org/wiki/WorkshopFOSS4G2007
This is what I started with and then made my own modifications. The
above workshop should walk you through how to setup a pgRouting without
my additional hacks which will only confuse you at the moment.
My dd_routing.php is a modified version of ax_routing.php that is
included in the tutorial tarball.
You might also want to read some of these pages if you have not already:
http://www.google.com/search?hl=en&q=pgRouting&btnG=Google+Search
Best regards,
-Steve W
Valeria Muñoz wrote:
> hi Stephen.. thank for the tips...
> I have reviewed the code but can only see the dd.html. can you send me
> the dd_routing.php? .
> please
> thanks for everything
> 2009/1/19 Stephen Woodbridge <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>>
> frank
> thanks for the tips. I use prRouting and create the table
> dijsktra_result. Now how can I implement with my mapfile? , how
> deliver the data .. have some sample code?
> thanks for your help.
> 2009/1/19 Frank Warmerdam <warmerdam at pobox.com
> <mailto:warmerdam at pobox.com> <mailto:warmerdam at pobox.com
> <mailto:warmerdam at pobox.com>>>
> Hi
> I would like to implement the service "optimum path
> between 2
> points," can someone help me to be able to implement it?. The
> general idea is that a user picks a point A and point B and a
> display on the map the best route to get from point A to B.
> Valeria,
> MapServer itself does not do route calculation. You might
> find some
> useful pointers on this page:
> http://wiki.osgeo.org/wiki/OpenRouter
> I think the pgRouting (built on postgres/postgis) is the best
> bet for
> integration with MapServer.
> So you have various options depending on the client software you are
> using. So here are some ideas for you:
> 1) put the route into a results table with a unique id, and pass the
> unique id back to the client where it can then request the route
> image via a mapserver mapfile the connects to the postgis database
> and requests the layer be drawn with the unique id to select the
> appropriate route.
> 2) make an ajax request to generate the route and return the
> polyline as an xml or json object back to the client. The client
> then parses the result document and displays the route over the map.
> 3) if you use OpenLayers for the client then you can use it to help
> you do 1) as an image, or 1) as a wfs layer, or 2) as a vector layer.
> You can look at the source for my demo page
> http://imaptools.com/leaddog/routing/dd.html which does this with a
> modified version of pgRouting (pgRouting does not return
> turn-by-turn directions), but you should be able to modify my code
> to work with pgRouting. I wrote a simple php script to proxy the
> route request into postgres and to format the results back to the
> client.
> Look this over and see how far you can get with this. If you get
> stuck, ask and I'm sure we can get you moving in the right direction.
