[mapserver-users] Mapscript won't load after PHP update
Dominik Schmid
dominik.schmid at ilu.ch
Thu Jan 22 11:49:24 EST 2009
So I've updated our PHP installation from 5.1.6 to 5.2.8 (we need PHP
version 5.2 or later for some other features we want to implement on the
same server that Mapserver is running on). I did so using yum update.
This is where problems started and Mapscript didn't load anymore.
I've then recompiled Mapserver 5.2.1 against version 5.2.8 of PHP which
goes through without a glitch. This did not fix the issue. PHP still
cannot (or refuses to) load Mapscript and throws the following error:
PHP Warning: dl() [<a href='function.dl'>function.dl</a>]: MapScript:
Unable to initialize module
Module compiled with module API=20050922, debug=0, thread-safety=0
PHP compiled with module API=20060613, debug=0, thread-safety=0
These options need to match in ......
I made double sure that I compiled against the correct (new) version of
PHP so that can't be the issue here. I have not found any information as
to what else I can check or as to what else I could be doing wrong so I
need to ask here.
Thanks in advance for any insight.
Dominik Schmid
Dipl. Umweltnaturwissenschafter ETH
ilu AG
Zentralstrasse 2a
CH-8610 Uster
Tel: +41 44 / 944 55 56 (Direktwahl)
Tel: +41 44 / 944 55 55 (allgemein)
Fax: +41 44 / 944 55 66
mailto:dominik.schmid at ilu.ch
http://www.ilu.ch
