[mapserver-users] dbox make_dlegend_xml_cgi.py XML error
Steve Lime
Steve.Lime at dnr.state.mn.us
Fri Jan 23 09:17:21 EST 2009
Hi Richard: Any chance you're running different versions of MapServer in the different environments? There
was a syntax change between 4.x and 5.x (minscale => minscaledenom) that is exposed by that script. If view
the source is any more information revealed? The server logs?
Steve
>>> "Richard Polk" <Richard.Polk at state.tn.us> 01/22/09 4:43 PM >>>
Can anyone assist with the below error? I am getting it when trying to generate my application legend with dBox.
The same make_dlegend_xml_cgi.py script works on my development and test servers but fails in production.
My OS is Window Server 2003 with IIS 6.
The XML page cannot be displayed
Cannot view XML input using XSL style sheet. Please correct the error and then click the Refresh button, or try again later.
End tag 'font' does not match the start tag 'body'. Error processing resource 'http://production/cgi-bin/make_dlegend_xml_cg...</font> </font> </font> </scr --> </obj --> </blockquote> </pre>----------^
