[mapserver-users] Get Feature Info into gmaps balloon
Guillaume Sueur
no-reply at neogeo-online.net
Fri Jan 23 17:42:07 EST 2009
try with :
using unique gid
in your data string
regards
guillaume
gzambotti a écrit :
> Hi there,
> I am new with mapserver.
> I use a WMS/mapserver (4.9) to Get Feature Info into a google maps balloon.
> If I set my mapfile to a shapefile everything works very well.
> When I try to use PostGIS I get this error (Content-type:
> application/vnd.ogc.se_xml ).
> any idea?
> many thanks, Giovanni
> Here my mapfile:
> LAYER
> NAME "ED_Total"
> MINSCALE 1000000
> CONNECTIONTYPE postgis
> CONNECTION "user=africamaps password=j0kerz dbname=africamaps
> host=localhost port=5432"
> #DATA "the_geom from ED_Total using unique gid USING SRID=4326"
> DATA "the_geom from (select gid, NAME, CITY, STATE, the_geom
> from ED_Total) as foo using unique the_geom using SRID=4326"
> #DATA "/opt/CGA/data/vec/gio1/shapefile/EDtotal"
> TYPE POINT
> METADATA
> "wms_title" "ED_Total"
> "wms_srs" "EPSG:4326 EPSG:900913 EPSG:41001 EPSG:54004"
> 'wms_include_items' 'all'
> "wms_onlineresource"
> "http://cga-3.hmdc.harvard.edu/cgi-bin/mapserv?map=/opt/CGA/newam/htdocs/gtest/ednet.map&"
> "ows_exceptions_format" "application/vnd.ogc.se_xml"
> "wms_exceptions_format" "application/vnd.ogc.se_xml "
> "wms_exceptions_format" "application-vnd.ogc.se_inimage"
> "wms_ature_info_mime_type" "text/html"
> END
> STATUS ON
> PROJECTION "+init=epsg:4326"
> END #projection
> CLASS
> NAME "lt 1"
> STYLE
> COLOR 255 255 250
> SYMBOL 'circle'
> SIZE 8.5
> END
> STYLE
> COLOR 255 0 0
> SYMBOL 'thickcross'
> SIZE 7.5
> END
> END #class
> HEADER "/opt/CGA/newam/htdocs/gtest/header.html"
> TEMPLATE "/opt/CGA/newam/htdocs/gtest/query.html"
> FOOTER "/opt/CGA/newam/htdocs/gtest/footer.html"
> END #layer
