You haven't set the UNITS for the map. The default is meters, is that correct for your setup? Steve >>> On 1/23/2009 at 6:25 PM, in message <1232756730020-2206899.post at n2.nabble.com>, boesiii <boesiii at yahoo.com> wrote: > The map file is attached along with an example image
