[mapserver-users] mapfile: displaying a feature from a shapefile.
kende
chankour at gmail.com
Sun Jan 25 11:15:31 EST 2009
Hello,
I installed HostGIS, and used the mapserver example1 as my template. My data
is in an shp file.
The layer with all the tracks (roads) is displaying correctly. What I am
unable to do is display the
road/track names on top.
This is my own shp file, the tracks have several features, one called
"road_name". I have googled,
and read most of the related stuff I could get my hands on, and tried
several 'ways' without luck.
I am pasting my cleaned up mapfile below (in the real file, my extent has
the actual lat/long values).
I would appreciate any help or suggestions on how to display the road name
field. (I am using the Windows
versions of Quantum GIS and GPS TrackMaker to look at those fields in the
shapefile).
Thanks.
============== my Mapfile ===========================
MAP
NAME mytown
SHAPEPATH /var/www/manual/examples/mytown/data
SIZE 700 500
UNITS dd
EXTENT x1 y1 x2 y2
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
IMAGECOLOR 255 255 255
IMAGEQUALITY 95
IMAGETYPE PNG
OUTPUTFORMAT
NAME "png24"
MIMETYPE "image/png"
DRIVER "AGG/PNG"
EXTENSION "png"
IMAGEMODE "RGBA"
TRANSPARENT off
END
FONTSET "../fonts/fonts.list"
WEB
MINSCALE 1
MAXSCALE 100000
IMAGEPATH "/maps/images.tmp/"
IMAGEURL "/images.tmp/"
# WMS server settings
METADATA
'wms_title' 'mytown'
'wms_onlineresource' 'http://localhost/cgi-bin/mapserv?map=wms.map&'
'wms_srs' 'EPSG:4326'
END
END
REFERENCE
STATUS ON
SIZE 240 157
EXTENT x1 y1 x2 y2
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
LEGEND
KEYSIZE 12 12
LABEL
TYPE truetype
FONT "LondonTube"
SIZE 9
COLOR 0 0 0
END
STATUS embed
POSITION ul
END
SCALEBAR
STATUS embed
TRANSPARENT off
INTERVALS 4
SIZE 200 3
UNITS kilometers
COLOR 250 250 250
OUTLINECOLOR 0 0 0
BACKGROUNDCOLOR 100 100 100
STYLE 0
POSTLABELCACHE true
LABEL
COLOR 0 0 90
#OUTLINECOLOR 200 200 200
SIZE small
END # Label
END # Reference
# Start of layer definitions
# Road tracks
LAYER
NAME 'mytown'
TYPE LINE
DATA '/var/www/manual/examples/mytown/data/mytown.shp'
METADATA
'gml_include_items' 'all'
END
DUMP TRUE
STATUS DEFAULT
TRANSPARENCY 80
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
CLASS
STYLE
COLOR 102 0 0
SIZE 2
SYMBOL "line_solid"
END
STYLE
COLOR 204 51 51
SIZE 1
SYMBOL "line_solid"
END
LABEL
TYPE truetype
FONT "PerspectiveBlack"
SIZE 11
END
END
END # layer road tracks
# LINE TYPES
SYMBOL
NAME "line_solid"
TYPE ellipse
POINTS
1 1
END
FILLED true
END
END # end of mapfile
View this message in context: http://n2.nabble.com/mapfile%3A-displaying-a-feature-from-a-shapefile.-tp2213523p2213523.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
