[mapserver-users] SLD and antialiasing
Yewondwossen Assefa
yassefa at dmsolutions.ca
Mon Jan 26 09:32:07 EST 2009
Peter Sykora wrote:
> Hi all,
> I would like to create a WMS with antialiased Polygons. The "ANTIALIAS true" statement in the style object works fine until I use an SLD to style my polygons.
> See the difference:
> - Styling with mapfile
> http://81.10.192.123:443/cgi/stat?LAYERS=stat&REASPECT=false&TRANSPARENT=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fpng&SRS=EPSG%3A31255&BBOX=39500,299250,81750,341500&WIDTH=256&HEIGHT=256
> - Styling with an external SLD
> http://81.10.192.123:443/cgi/stat?LAYERS=stat&REASPECT=false&TRANSPARENT=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fpng&SRS=EPSG%3A31255&BBOX=39500,299250,81750,341500&WIDTH=256&HEIGHT=256&sld=http://www.carto.net/ps/sld/sld_stat.xml
> Certainly there is no possiblity to define the antialiasing in the SLD, but I wonder whether there is a mechanism to keep the antialias statement somehow in the styling object, independently of the definition in the SLD.
Peter,
This is not possible currently. As you noted there are elements that are
not translated between SLD-Mapserver. As suggested agg would give
anti-aliasing by default and could be work around.
Best Regards
> Thanks in advance for any ideas
> Peter
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
