[mapserver-users] Get Feature Info into gmaps balloon
gzambotti
g.zambotti at gmail.com
Mon Jan 26 09:37:06 EST 2009
many thanks Guillaume
it works fine now!
Best
Giovanni
On Fri, Jan 23, 2009 at 5:42 PM, Guillaume Sueur-2 (via Nabble) <
ml-user+137812-417701502 at n2.nabble.com<ml-user%2B137812-417701502 at n2.nabble.com>
> wrote:
> try with :
> using unique gid
> in your data string
> regards
> guillaume
> gzambotti a écrit :
> > Hi there,
> > I am new with mapserver.
> > I use a WMS/mapserver (4.9) to Get Feature Info into a google maps
> balloon.
> > If I set my mapfile to a shapefile everything works very well.
> > When I try to use PostGIS I get this error (Content-type:
> > application/vnd.ogc.se_xml ).
> > any idea?
> > many thanks, Giovanni
> > Here my mapfile:
> > LAYER
> > NAME "ED_Total"
> > MINSCALE 1000000
> > CONNECTIONTYPE postgis
> > CONNECTION "user=africamaps password=j0kerz dbname=africamaps
> > host=localhost port=5432"
> > #DATA "the_geom from ED_Total using unique gid USING
> SRID=4326"
> > DATA "the_geom from (select gid, NAME, CITY, STATE, the_geom
> > from ED_Total) as foo using unique the_geom using SRID=4326"
> > #DATA "/opt/CGA/data/vec/gio1/shapefile/EDtotal"
> > TYPE POINT
> > METADATA
> > "wms_title" "ED_Total"
> > "wms_srs" "EPSG:4326 EPSG:900913 EPSG:41001 EPSG:54004"
> > 'wms_include_items' 'all'
> > "wms_onlineresource"
> http://cga-3.hmdc.harvard.edu/cgi-bin/mapserv?map=/opt/CGA/newam/htdocs/gtest/ednet.map&"
> > "ows_exceptions_format" "application/vnd.ogc.se_xml"
> > "wms_exceptions_format" "application/vnd.ogc.se_xml "
> > "wms_exceptions_format" "application-vnd.ogc.se_inimage"
> > "wms_ature_info_mime_type" "text/html"
> > END
> > STATUS ON
> > PROJECTION "+init=epsg:4326"
> > END #projection
> > CLASS
> > NAME "lt 1"
> > STYLE
> > COLOR 255 255 250
> > SYMBOL 'circle'
> > SIZE 8.5
> > END
> > STYLE
> > COLOR 255 0 0
> > SYMBOL 'thickcross'
> > SIZE 7.5
> > END
> > END #class
> > HEADER "/opt/CGA/newam/htdocs/gtest/header.html"
> > TEMPLATE "/opt/CGA/newam/htdocs/gtest/query.html"
> > FOOTER "/opt/CGA/newam/htdocs/gtest/footer.html"
> > END #layer
> mapserver-users at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2206440&i=0>
> This email is a reply to your post @
> http://n2.nabble.com/Get-Feature-Info-into-gmaps-balloon-tp2206135p2206440.html
> You can reply by email or by visting the link above.
Giovanni Zambotti
34 Prince st, Cambridge MA
02139 USA
Phone: (617) 492 - 0359
View this message in context: http://n2.nabble.com/Get-Feature-Info-into-gmaps-balloon-tp2206135p2218219.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090126/f60d555a/attachment.html
