[mapserver-users] Raster ESRI GRID path error
Frank Warmerdam
warmerdam at pobox.com
Wed Jan 28 11:38:53 EST 2009
simone.frigerio wrote:
> Hi,
> I inserted a raster GRID in my mapfile but in map appears this kind of
> error:
> Message : Mapserver error: Error in msDrawRaster() : /asci_co2 using
> full path /asci_co2
> Probably I did an error in the path, but I don't know what is it really!
> GRID is inside DATA folder (SHAPEPATH) and it is represented by a
> folder "asci_co2"" and a folder "info". The layer parameters are:
> LAYER
> NAME "asci_co2"
> TYPE RASTER
> DATA "/asci_co2"
> TEMPLATE "ttt"
> TRANSPARENCY 100
> METADATA
> "force_imagetype" "jpeg"
> END
> END
Simo,
If you include a slash at the beginning of the filename it is assumed
to be an absolute path from root. I think you just want to use:
DATA "asci_co2"
Good luck,
and watch the world go round - Rush | Geospatial Programmer for Rent
