[mapserver-users] problem with raster data..
Christy Nieman
cnieman at dmsolutions.ca
Thu Jan 29 21:27:12 EST 2009
Hi Melvin,
Using a tool such as gdaltindex (see http://www.gdal.org/gdaltindex.html
and http://mapserver.org/optimization/tileindex.html#tileindex) you can
create a shapefile tile index that will give MapServer the information
it needs to use the required rasters for the current map extent. In the
shapefile there will be one feature that is the bounding box of each
raster file, and an attribute that contains the path to the raster that
each feature represents.
Christy
MeLv1n wAuRaN wrote:
> hi all,
> right now i have 50 .TIF files (a whole map of my region) my question
> is, is it possible for mapserver to load 50 .TIF files all together as
> a basemap? because from the tutorial i read, the samples only load 1
> raster file..so, i'm wondering if it's possible to load all the 50 TIF
> files to the same .MAP
> if not, then how do i merge all the TIF files into a single TIF?
> because when i load them all together in ArcMap it forms a whole map.
> for the information, i'm still a newbie...so i still need alot of
> advices from the experts.
> thanks for your help,
> Melvin
> mapserver-users at lists.osgeo.org
