[mapserver-users] Accessing metadata from datafile in mapfile
Espen.Messel at ffi.no
Fri Jan 30 05:08:37 EST 2009
Hello.
Is it possible to access metadata from the data file in a mapfile? We
get data from variable sources and need to scale the colour lookup table
with a metadata item from the data file. We tried to write the name of
the metadata directly in the mapfile, but it didn't work. Look below in
the EXPRESSION line in the mapfile.
I have also added the output from the gdalinfo command.
Regards,
Espen Messel
LAYER
NAME "radar"
STATUS DEFAULT
TYPE RASTER
DUMP TRUE
STATUS OFF
DATA
'HDF5:"d:\\etc\data\norsa.ss.pcappi-1116-dbz.aeqd-1000.20080828T080038Z.
hdf"://image1/data'
METADATA
"wms_extent" "5.706560 61.303028 15.411345 65.598137"
"ows_include_items" "all"
"ows_title" "radar"
END
CLASS
EXPRESSION (([pixel]*[what:gain]) >= 64)
COLOR 255 0 0
END
END
gdalinfo output
Driver: HDF5/Hierarchical Data Format Release 5
Files: norsa.ss.pcappi-1116-dbz.aeqd-1000.20080828T080038Z.hdf
Size is 512, 512
Coordinate System is `'
Metadata:
what:gain=0.500000
what:offset=-31.500000
what:nodata=255.000000
Subdatasets:
SUBDATASET_0_NAME=HDF5:"norsa.ss.pcappi-1116-dbz.aeqd-1000.20080828T0800
38Z.hdf"://image1/data
SUBDATASET_0_DESC=[480x480] //image1/data (8-bit unsigned character)
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 512.0)
Upper Right ( 512.0, 0.0)
Lower Right ( 512.0, 512.0)
Center ( 256.0, 256.0)
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090130/c64e0368/attachment.html
