[mapserver-users] Importing a Google/Yahoo maps raster layer
Adrian Popa
adrian_gh.popa at romtelecom.ro
Tue Jun 2 01:23:56 EDT 2009
Thank you for the info - I will give it a try on a testbed installation :)
Christopher Schmidt wrote:
> On Mon, Jun 01, 2009 at 05:20:25PM +0300, Adrian Popa wrote:
>> Hello Christopher,
>> Your example has the elements that I need :) Is this basic functionality
>> included in openlayers by default, or is it an addon?
>> Also - will openlayers work with mapserver by default - or through WMS
>> (I don't have experience with WMS)?
> Both, but WMS is highly recommended, because using MapServer as CGI is
> prone to hide errors due to misconfiguration. (Setting up WMS requires
> only adding:
> metadata
> web
> wms_srs "EPSG:4326"
> end
> end
> to your mapfile to work minimally; everything else is optional.)
> The recovery map example has a significant amount of code, but it is
> using the trunk version of OpenLayers with no additional features. The
> UI, some of the popups, the layer addition/removal are all additional
> pieces added to that UI, but there are other toolkits (Like GeoExt) that
> provide these in open source software as well.
> Best Regards,
Adrian Popa
NOC Division
Network Engineer
Divizia Centrul National de Operare Retea
Departament Transport IP & Metro
Compartiment IP Core & Backbone
Phone: +40 21 400 3099
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090602/8b682484/attachment.html
