[mapserver-users] PHP Mapscript - layer->queryByAttribute problem
Worth Lutz
wal3 at mindspring.com
Thu Jun 4 09:43:58 EDT 2009
Using MapServer 5.4.0:
I have two shapefile layers in NC State Plane system, one in ft and one in
meters. The PROJECTION in the layers allows the map to be drawn correctly.
My problem occurs when trying to use PHP mapscript to queryByAttribute. I
am locating NC counties from two different shapefiles. Using the layer
which is the same projection at the map there is no problem. Using the
other layer, the bounds of the query result appear to be in meters and not
ft. Is this normal? Do I have to make the conversion?
Using mapserver 5.4.0
PHP mapscript:
$ms = ms_newMapObj( $mapfile );
$ms->setSize($mapVpWidth,$mapVpHeight);
$groupnames = $ms->getAllGroupNames();
for($i=0; $i < sizeof($layerNames); $i++) {
if(in_array($layerNames[$i],$groupnames)) {
$layerIndexes = $ms->getLayersIndexByGroup($layerNames[$i]);
for($j=0; $j < sizeof($layerIndexes); $j++) {
$layer = $ms->getLayer($layerIndexes[$j]);
$layer->set("status", MS_ON);
} else {
$layer = $ms->getLayerByName($layerNames[$i]);
$layer = $ms->getLayerByName($layername);
$layer->set('status', MS_ON);
$layer->queryByAttributes($attribute, $expression, MS_MULTIPLE);
$numresults = $layer->getNumResults();
if ($numresults < 1) {
$err->msg = 'No results in '.$layername.' for '.$attribute.' =
'.$expression.'.';
$error = true;
} else {
$result = $layer->getResult(0);
$layer->open();
$shapeObj = $layer->getFeature($result->shapeindex);
$layer->close();
$minx = $shapeObj->bounds->minx;
$miny = $shapeObj->bounds->miny;
$maxx = $shapeObj->bounds->maxx;
$maxy = $shapeObj->bounds->maxy;
$ms->setExtent( $minx, $miny, $maxx, $maxy );
$img = $ms->drawquery();
$tmpMapImg = $img->saveWebImage();
*Layer data from mapfile:
LAYER
NAME "county_outlines"
TYPE POLYGON
MINSCALE 1200
MAXSCALEDENOM 3750001
STATUS off
PROJECTION
"init=epsg:2264" # NAD 83 North Carolina (ftUS)
END
DATA CountyBoundaryShoreline
TEMPLATE void
CLASS
NAME "county lines"
STYLE
OUTLINECOLOR 128 128 128
END
END
END
LAYER
NAME "county_outlines2"
TYPE POLYGON
MINSCALE 1200
STATUS off
PROJECTION
"init=epsg:32119" # NAD 83 North Carolina (meters US)
END
DATA cb100_poly
TEMPLATE void
LABELITEM "co_name"
LABELMAXSCALEDENOM 1500000
LABELMINSCALEDENOM 100000
CLASS
NAME "cb100_poly"
STYLE
OUTLINECOLOR 200 0 0
END
LABEL
COLOR 0 0 0
#SHADOWCOLOR 218 218 218
#SHADOWSIZE 2 2
TYPE BITMAP
SIZE tiny
POSITION CC
PARTIALS FALSE
BUFFER 2
END
END
END
