[mapserver-users] Re: Upgrading 5.2 -> 5.4 generating CGI error
on IIS(5.1 and 6.0) ... Possible BUG?
Brian Fischer
bfischer at houstoneng.com
Wed Jun 10 09:54:09 EDT 2009
I would agree with Paul. I am running 5.2 and previous version just fine as well.
Brian Fischer, CFM GIS Project Manager
Houston Engineering, Inc.
Phone: W: 763.493.4522 / M: 763.229.2734
Sent: Wednesday, June 10, 2009 8:46 AM
To: Tamas Szekeres
Cc: Brian Fischer; mapserver-users at lists.osgeo.org; Daniel Morissette; Steve Lime
Subject: Re: [mapserver-users] Re: Upgrading 5.2 -> 5.4 generating CGI error on IIS(5.1 and 6.0) ... Possible BUG?
I don´t think its related to security settings... I can run the CGI on 5.2 ... And as well with fastcgi on 5.4 ...
Anyway I gave all permission to all user in mapserver directory and app directory... Nothing changes...
Anyone test that with Postgis layer? I´m trying to get a shapefile to test ...
Paul
On Tue, Jun 9, 2009 at 7:02 PM, Tamas Szekeres <szekerest at gmail.com<mailto:szekerest at gmail.com>> wrote:
Paul,
I've just tried with the latest 5.4 version and worked fine though I'm using OGR/mapinfo.tab data source.
I suspect you may run into a problem related to the possible differences in the security settings. Some files may not be accessible by the current user executing mapserv.exe which may be "IUSR_[computername]" for the normal CGI and "NT AUTHORITY/NETWORK SERVICE" for the fast cgi option by default.
Best regards,
Tamas
2009/6/9 Paul james <pauljame at gmail.com<mailto:pauljame at gmail.com>>
Just one update in my tests...
Using FASTCGI It worked FINE (mapserver 5.4)...
I added a bug ticket : http://trac.osgeo.org/mapserver/ticket/3049
Paul
On Tue, Jun 2, 2009 at 10:12 AM, Paul james <pauljame at gmail.com<mailto:pauljame at gmail.com>> wrote:
Probably is a mapserver CGI bug...
Paul
On Sat, May 30, 2009 at 11:56 PM, Brian Fischer <bfischer at houstoneng.com<mailto:bfischer at houstoneng.com>> wrote:
Paul,
Just to let you know you are not alone. I am experiencing the same problem with MS4W 3.0 beta 1 and 2. I’ve reported it as a bug to the MS4W project. Here’s a link to the bug report http://bugzilla.maptools.org/show_bug.cgi?id=2043. I haven’t heard anything back on a solution yet. I’m not sure if this is a MapServer bug or a bug with the way the MS4W package was compiled. It runs fine of Apache for me.
Brian Fischer
From: mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org> [mailto:mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org>] On Behalf Of Paul james
Sent: Friday, May 29, 2009 1:08 PM
To: Steve Lime
Cc: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>; Daniel Morissette
http://localhost/cgi-bin/mapserv.exe?map=C%3A%2Finetpub%2Fwwwroot%2FOpenlayer%2FFiles%2FMapserver%2FMap.map&mode=map&map_imagetype=png&mapext=-180+0+-90+90&imgext=-180+0+-90+90&map_size=256+256&imgx=128&imgy=128&imgxy=256+256
Paul
On Fri, May 29, 2009 at 3:01 PM, Steve Lime <Steve.Lime at dnr.state.mn.us<mailto:Steve.Lime at dnr.state.mn.us>> wrote:
What's the full URL submitted against the CGI?
>>> On 5/29/2009 at 12:59 PM, in message
<33fad6880905291059i5602a89q84d7673ddcfff511 at mail.gmail.com<mailto:33fad6880905291059i5602a89q84d7673ddcfff511 at mail.gmail.com>>, Paul
james
> 1 - I tried with 1500,1400,1310,development version(1500) and ms4w
beta...
> 2 - Ím using normal CGI
> 3 - My tests are only with Postgis... Íll generate a shapefile to
test
> later ...
> Paul
> On Fri, May 29, 2009 at 2:27 PM, Tamas Szekeres <szekerest at gmail.com<mailto:szekerest at gmail.com>>
wrote:
>> Hi Paul,
>> Did you experience the same with the release-1310 and release-1400
>> versions? Did you experience the same with the development version?
>> Are you using fastCGI or normal cgi?
>> Is this just a PostGIS related problem or you get the same with a
simple
>> shapefile?
>> Sorry for the bunch of the questions...
>> Best regards,
>> Tamas
>> 2009/5/29 Paul james <pauljame at gmail.com<mailto:pauljame at gmail.com>>
>>> Yes Daniel... I deleted all previous files and put only 5.4
files... My
>>> mapscript application is working fine on 5.4...
>>> But the CGI dont...
>>> Tested on Windows XP (IIS 5.1) and Windows 2003(IIS 6.0)...
>>> Paul
>>> On Fri, May 29, 2009 at 12:56 PM, Daniel Morissette <
>>> dmorissette at mapgears.com<mailto:dmorissette at mapgears.com>> wrote:
>>>> Paul james wrote:
>>>>> Hi Daniel...
>>>>> I got the binaries from Tamas build :
>>>>> http://vbkto.dyndns.org:1280/sdk/Default.aspx
>>>>> And from MS4W 3.0 beta2...
>>>>> Same result with both...
>>>>> That error you got is my fault... I took off the :
>>>>> IMAGE "..\Map.png"
>>>>> from REFERENCE definition when copy the code to email...
>>>>> My application works fine with 5.2 binary in iis 5.1 and 6.0
>>>>> Just replacing with 5.4 binary I got that 502 error...
>>>> Hopefully you always make sure you update all DLLs as well when
you
>>>> "replace with 5.4 binary"? Even if the DLLs have the same names,
if they
>>>> come from different build environments or versions they may not
be
>>>> compatible and could cause the kind of crashes that you are
experiencing.
>>>> Daniel
>>>> Daniel Morissette
>>>> http://www.mapgears.com/
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090610/fd88e0d0/attachment-0001.html
