[mapserver-users] Re: Upgrading 5.2 -> 5.4 generating CGI error
on IIS(5.1 and 6.0) ... Possible BUG?
Tamas Szekeres
szekerest at gmail.com
Wed Jun 10 12:14:15 EDT 2009
It would anyway be helpful if you could describe the steps to reproduce the
issue. I'm afraid I won't be able to find out the problem without inspecting
that locally by using a debug version of the builds. There have been a lot
of changes between 5.2 and 5.4 so it's quite difficult to identify the
location and the related changeset just by looking into the change log in
the subversion.
Best regards,
Tamas
2009/6/10 Brian Fischer <bfischer at houstoneng.com>
> I would agree with Paul. I am running 5.2 and previous version just fine
> as well.
> *Brian Fischer,* CFM GIS Project Manager
> *Houston Engineering, Inc.*
> Phone: W: 763.493.4522 / M: 763.229.2734
> *From:* Paul james [mailto:pauljame at gmail.com]
> *Sent:* Wednesday, June 10, 2009 8:46 AM
> *To:* Tamas Szekeres
> *Cc:* Brian Fischer; mapserver-users at lists.osgeo.org; Daniel Morissette;
> Steve Lime
> *Subject:* Re: [mapserver-users] Re: Upgrading 5.2 -> 5.4 generating CGI
> error on IIS(5.1 and 6.0) ... Possible BUG?
> I don´t think its related to security settings... I can run the CGI on 5.2
> ... And as well with fastcgi on 5.4 ...
> Anyway I gave all permission to all user in mapserver directory and app
> directory... Nothing changes...
> Anyone test that with Postgis layer? I´m trying to get a shapefile to test
> Paul
> On Tue, Jun 9, 2009 at 7:02 PM, Tamas Szekeres <szekerest at gmail.com>
> wrote:
> Paul,
> I've just tried with the latest 5.4 version and worked fine though I'm
> using OGR/mapinfo.tab data source.
> I suspect you may run into a problem related to the possible differences in
> the security settings. Some files may not be accessible by the current user
> executing mapserv.exe which may be "IUSR_[computername]" for the normal CGI
> and "NT AUTHORITY/NETWORK SERVICE" for the fast cgi option by default.
> Best regards,
> Tamas
> 2009/6/9 Paul james <pauljame at gmail.com>
> Just one update in my tests...
> Using FASTCGI It worked FINE (mapserver 5.4)...
> I added a bug ticket : http://trac.osgeo.org/mapserver/ticket/3049
> Paul
> On Tue, Jun 2, 2009 at 10:12 AM, Paul james <pauljame at gmail.com> wrote:
> Probably is a mapserver CGI bug...
> Paul
> On Sat, May 30, 2009 at 11:56 PM, Brian Fischer <bfischer at houstoneng.com>
> wrote:
> Paul,
> Just to let you know you are not alone. I am experiencing the same problem
> with MS4W 3.0 beta 1 and 2. I’ve reported it as a bug to the MS4W project.
> Here’s a link to the bug report
> http://bugzilla.maptools.org/show_bug.cgi?id=2043. I haven’t heard
> anything back on a solution yet. I’m not sure if this is a MapServer bug or
> a bug with the way the MS4W package was compiled. It runs fine of Apache
> for me.
> Brian Fischer
> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Paul james
> *Sent:* Friday, May 29, 2009 1:08 PM
> *To:* Steve Lime
> *Cc:* mapserver-users at lists.osgeo.org; Daniel Morissette
> http://localhost/cgi-bin/mapserv.exe?map=C%3A%2Finetpub%2Fwwwroot%2FOpenlayer%2FFiles%2FMapserver%2FMap.map&mode=map&map_imagetype=png&mapext=-180+0+-90+90&imgext=-180+0+-90+90&map_size=256+256&imgx=128&imgy=128&imgxy=256+256
> Paul
> On Fri, May 29, 2009 at 3:01 PM, Steve Lime <Steve.Lime at dnr.state.mn.us>
> wrote:
> What's the full URL submitted against the CGI?
> >>> On 5/29/2009 at 12:59 PM, in message
> <33fad6880905291059i5602a89q84d7673ddcfff511 at mail.gmail.com>, Paul
> james
> > 1 - I tried with 1500,1400,1310,development version(1500) and ms4w
> beta...
> > 2 - Ím using normal CGI
> > 3 - My tests are only with Postgis... Íll generate a shapefile to
> test
> > later ...
> > Paul
> > On Fri, May 29, 2009 at 2:27 PM, Tamas Szekeres <szekerest at gmail.com>
> wrote:
> >> Hi Paul,
> >> Did you experience the same with the release-1310 and release-1400
> >> versions? Did you experience the same with the development version?
> >> Are you using fastCGI or normal cgi?
> >> Is this just a PostGIS related problem or you get the same with a
> simple
> >> shapefile?
> >> Sorry for the bunch of the questions...
> >> Best regards,
> >> Tamas
> >> 2009/5/29 Paul james <pauljame at gmail.com>
> >>> Yes Daniel... I deleted all previous files and put only 5.4
> files... My
> >>> mapscript application is working fine on 5.4...
> >>> But the CGI dont...
> >>> Tested on Windows XP (IIS 5.1) and Windows 2003(IIS 6.0)...
> >>> Paul
> >>> On Fri, May 29, 2009 at 12:56 PM, Daniel Morissette <
> >>> dmorissette at mapgears.com> wrote:
> >>>> Paul james wrote:
> >>>>> Hi Daniel...
> >>>>> I got the binaries from Tamas build :
> >>>>> http://vbkto.dyndns.org:1280/sdk/Default.aspx
> >>>>> And from MS4W 3.0 beta2...
> >>>>> Same result with both...
> >>>>> That error you got is my fault... I took off the :
> >>>>> IMAGE "..\Map.png"
> >>>>> from REFERENCE definition when copy the code to email...
> >>>>> My application works fine with 5.2 binary in iis 5.1 and 6.0
> >>>>> Just replacing with 5.4 binary I got that 502 error...
> >>>> Hopefully you always make sure you update all DLLs as well when
> you
> >>>> "replace with 5.4 binary"? Even if the DLLs have the same names,
> if they
> >>>> come from different build environments or versions they may not
> be
> >>>> compatible and could cause the kind of crashes that you are
> experiencing.
> >>>> Daniel
> >>>> Daniel Morissette
> >>>> http://www.mapgears.com/
> >>> _______________________________________________
> >>> mapserver-users mailing list
> >>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090610/b3af1b87/attachment.html
