[mapserver-users] WFS GetFeature problem
Balázs Bámer
bamerbalazs at gmail.com
Thu Jun 11 03:31:07 EDT 2009
Hi All,
Mapserver is 5.4.1 under Ubuntu 8.10, compiled after
./configure --with-oci
--with-oraclespatial=/usr/local/instantclient_11_1 --with-proj
--with-threads --with-gdal --with-ogr --with-jpeg --with-png=/usr/lib
--with-php=/usr/include/php5 --with-wmsclient --with-wfsclient
--with-fastcgi=/usr --with-wfs
I try to use Mapserver WFS to query features by = operator. The
problem is altough the feature is found and returned, the attributes
are missing. The DescribeFeature request
http://att-it.homelinux.net:22080/cgi-bin/ms-5.4.1/blokknez.fcgi?SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=blokk2009&OUTPUTFORMAT=XMLSCHEMA
returns
<schema targetNamespace="http://mapserver.gis.umn.edu/mapserver"
elementFormDefault="qualified" version="0.1">
<import namespace="http://www.opengis.net/gml"
schemaLocation="http://schemas.opengis.net/gml/2.1.2/feature.xsd"/>
<element name="blokk2009" type="ms:blokk2009Type"
substitutionGroup="gml:_Feature"/>
<complexType name="blokk2009Type">
<complexContent>
<extension base="gml:AbstractFeatureType">
<sequence>
<element name="msGeometry" type="gml:GeometryPropertyType"
minOccurs="0" maxOccurs="1"/>
</sequence>
</extension>
</complexContent>
</complexType>
</schema>
as far as I know, attributes should be described in the <sequence> tag.
My mapfile is (without other layers)
MAP
NAME BLOKKNEZ
STATUS ON
SIZE 650 500
# xmin ymin xmax ymax?
EXTENT 420000 40000 950000 370000
UNITS METERS
PROJECTION
"init=epsg:23700"
END
SHAPEPATH "."
IMAGECOLOR 200 200 200
IMAGETYPE png32
FONTSET fonts.txt
DEBUG 5
CONFIG "MS_ERRORFILE" "/var/log/mapserver-5.4.1/error.txt"
CONFIG "ON_MISSING_DATA" "LOG"
WEB
MINSCALEDENOM 10000
MAXSCALEDENOM 1000000
IMAGEPATH "/tmp"
IMAGEURL "/tmp"
LOG "/var/log/mapserver-5.4.1/ms_error.txt"
METADATA
"wms_title" "Blokkhatar nezegeto"
"wfs_title" "Blokkhatar nezegeto"
"wms_onlineresource"
"http://att-it.homelinux.net:22080/cgi-bin/ms-5.4.1/blokknez.fcgi?"
"wfs_onlineresource"
"wms_srs" "EPSG:23700"
"wfs_srs" "EPSG:23700"
END
END
LEGEND
IMAGECOLOR 255 255 255
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
SCALEBAR
LABEL
COLOR 0 0 0
SIZE SMALL
END
SIZE 150 5
COLOR 255 255 255
BACKGROUNDCOLOR 0 0 0
OUTLINECOLOR 0 0 0
UNITS meters
INTERVALS 5
STATUS ON
END
QUERYMAP
STYLE HILITE
COLOR 255 0 0
END
OUTPUTFORMAT
NAME png32
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGBA
EXTENSION "png"
END
LAYER
PROCESSING "CLOSE_CONNECTION=DEFER"
NAME blokk2009
METADATA
"DESCRIPTION" "blokk 2009"
"wms_title" "blokk 2009"
"wfs_title" "blokk 2008"
"ows_include_items" "all"
"ows_extent" '426400 43800 937400 362900'
"wfs_featureid" "tfotvbaz"
END
PROJECTION
"init=epsg:23700"
END
TYPE POLYGON
MINSCALEDENOM 999
MAXSCALEDENOM 200001
STATUS ON
CONNECTIONTYPE oraclespatial
CONNECTION "gis/gis@(DESCRIPTION=(ADDRESS_LIST=(ADDRESS=(PROTOCOL=TCP)(HOST=200.1.1.25)(PORT=1521)))(CONNECT_DATA=(SID=db2)))"
DATA "bgeom from (SELECT bgeom,bloaz,bpter/10000.0 as
bpterha,tfotvbaz FROM tfotvb where tolda =
to_Date('20090303','YYYYMMDD')) using unique tfotvbaz SRID 23700"
CLASS
NAME "blokk2009"
STYLE
OUTLINECOLOR 55 55 255
END
END
DUMP TRUE
TEMPLATE "template.html"
DEBUG 5
END # layer blokk2009
END # Map File
What is missing?
Thank you in advance.
Best regards: Balázs
