[mapserver-users] WFS GetFeature problem
Balázs Bámer bamerbalazs at gmail.com
Thu Jun 11 00:31:07 PDT 2009
Hi All,
Mapserver is 5.4.1 under Ubuntu 8.10, compiled after
./configure --with-oci
--with-oraclespatial=/usr/local/instantclient_11_1  --with-proj
--with-threads --with-gdal --with-ogr  --with-jpeg --with-png=/usr/lib
--with-php=/usr/include/php5 --with-wmsclient --with-wfsclient
--with-fastcgi=/usr --with-wfs
I try to use Mapserver WFS to query features by = operator. The
problem is altough the feature is found and returned, the attributes
are missing. The DescribeFeature request
http://att-it.homelinux.net:22080/cgi-bin/ms-5.4.1/blokknez.fcgi?SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=blokk2009&OUTPUTFORMAT=XMLSCHEMA
returns
<schema targetNamespace="http://mapserver.gis.umn.edu/mapserver"
elementFormDefault="qualified" version="0.1">
<import namespace="http://www.opengis.net/gml"
schemaLocation="http://schemas.opengis.net/gml/2.1.2/feature.xsd"/>
<element name="blokk2009" type="ms:blokk2009Type"
substitutionGroup="gml:_Feature"/>
<complexType name="blokk2009Type">
<complexContent>
<extension base="gml:AbstractFeatureType">
<sequence>
<element name="msGeometry" type="gml:GeometryPropertyType"
minOccurs="0" maxOccurs="1"/>
</sequence>
</extension>
</complexContent>
</complexType>
</schema>
as far as I know, attributes should be described in the <sequence> tag.
My mapfile is (without other layers)
MAP
NAME BLOKKNEZ
STATUS ON
SIZE 650 500
# xmin ymin xmax ymax?
EXTENT 420000 40000 950000 370000
UNITS METERS
PROJECTION
  "init=epsg:23700"
END
SHAPEPATH "."
IMAGECOLOR 200 200 200
IMAGETYPE png32
FONTSET fonts.txt
DEBUG 5
CONFIG "MS_ERRORFILE" "/var/log/mapserver-5.4.1/error.txt"
CONFIG "ON_MISSING_DATA" "LOG"
WEB
  MINSCALEDENOM 10000
  MAXSCALEDENOM 1000000
  IMAGEPATH "/tmp"
  IMAGEURL "/tmp"
  LOG "/var/log/mapserver-5.4.1/ms_error.txt"
  METADATA
    "wms_title" "Blokkhatar nezegeto"
    "wfs_title" "Blokkhatar nezegeto"
    "wms_onlineresource"
"http://att-it.homelinux.net:22080/cgi-bin/ms-5.4.1/blokknez.fcgi?"
    "wfs_onlineresource"
    "wms_srs" "EPSG:23700"
    "wfs_srs" "EPSG:23700"
  END
END
LEGEND
  IMAGECOLOR 255 255 255
  LABEL
    TYPE BITMAP
    SIZE MEDIUM
    COLOR 0 0 89
  END
  STATUS ON
END
SCALEBAR
  LABEL
    COLOR 0 0 0
    SIZE SMALL
  END
  SIZE 150 5
  COLOR 255 255 255
  BACKGROUNDCOLOR 0 0 0
  OUTLINECOLOR 0 0 0
  UNITS meters
  INTERVALS 5
  STATUS ON
END
QUERYMAP
  STYLE HILITE
  COLOR 255 0 0
END
OUTPUTFORMAT
  NAME png32
  DRIVER "GD/PNG"
  MIMETYPE "image/png"
  IMAGEMODE RGBA
  EXTENSION "png"
END
LAYER
  PROCESSING "CLOSE_CONNECTION=DEFER"
  NAME blokk2009
  METADATA
    "DESCRIPTION" "blokk 2009"
    "wms_title" "blokk 2009"
    "wfs_title" "blokk 2008"
    "ows_include_items" "all"
    "ows_extent" '426400 43800 937400 362900'
    "wfs_featureid" "tfotvbaz"
  END
  PROJECTION
    "init=epsg:23700"
  END
  TYPE POLYGON
  MINSCALEDENOM 999
  MAXSCALEDENOM 200001
  STATUS ON
  CONNECTIONTYPE oraclespatial
  CONNECTION "gis/gis@(DESCRIPTION=(ADDRESS_LIST=(ADDRESS=(PROTOCOL=TCP)(HOST=200.1.1.25)(PORT=1521)))(CONNECT_DATA=(SID=db2)))"
  DATA "bgeom from (SELECT bgeom,bloaz,bpter/10000.0 as
bpterha,tfotvbaz FROM tfotvb where tolda =
to_Date('20090303','YYYYMMDD')) using unique tfotvbaz SRID 23700"
  CLASS
    NAME "blokk2009"
    STYLE
      OUTLINECOLOR 55 55 255
    END
  END
  DUMP TRUE
  TEMPLATE "template.html"
  DEBUG 5
END # layer blokk2009
END # Map File
What is missing?
Thank you in advance.
Best regards: Balázs
More information about the MapServer-users mailing list
