[mapserver-users] How to label a feature once.
Paul Moen
pmoen at offroadsoftware.com
Fri Jun 12 00:15:15 EDT 2009
I figured it out. The images I am using are tiled so there are 4
images server by Mapserver with each labeled one time, which gives the
appearance of 4 labels on one feature. So, Mapserver is working
exactly the way it should and I am not.
On Jun 11, 2009, at 11:09 PM, David Nugent wrote:
> On Fri, 12 Jun 2009 13:34:06 +1000, Paul Moen <pmoen at offroadsoftware.com
> > wrote:
>> Thanks for the reply. Unfortunately for me, that was the first
>> thing that I tried. No matter what value I put in for MINDISTANCE
>> the output remained the same.
> See if POSITION CC helps.
> IIRC there is some strange interaction between MINDISTANCE and
> POSITION AUTO.
> Also try MINDISTANCE AUTO.
> Mapserver is not without some quirks. :)
> Regards,
> David
>> Thanks,
>> Paul
>>> On Fri, 12 Jun 2009 12:59:55 +1000, Paul Moen <pmoen at offroadsoftware.com
>>> > wrote:
>>>> Is there anyway to label a polygon once? One feature one label.
>>>> I am
>>>> using Mapserver 5.4.1. Image below shows the problem, there seem
>>>> to
>>>> be 4 labels in each township polygon.
>>> I would usually use MINDISTANCE with a large value in the LABEL
>>> section to solve this.
>>> Regards,
>>> David
