[mapserver-users] R
Thomas Bonfort
thomas.bonfort at camptocamp.com
Fri Jun 12 03:26:12 EDT 2009
> Since the wiki is pretty much broken now (moved, unchanged base href and so
> on), I'm assuming the outline was done with a filled "bar" symbol with
> negative gap under the road line since it looks similar to the solution I
> eventually wound up with to get the borders without closing the ends of the
> segments.
no, they are normal lines, except the first style (the thickest one)
has butt caps.
regards,
thomas
