[mapserver-users] Ignoring top level settings
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Mon Jun 15 10:15:46 EDT 2009
Try using a valid WMS request. &mode=map is Mapserver option, on the other hand your request is missing a few compulsory WMS parameters. Here is an excerpt from Mapserver WMS document (http://mapserver.org/ogc/wms_server.html):
Test With a GetMap Request
OK, now that we know that our server can produce a valid XML GetCapabilities response we should test the GetMap request. MapServer only checks for a few of the required GetMap parameters, so both of the minimum MapServer parameters and a valid GetMap request will be explained below.
The following is a list of the required GetMap parameters according to the WMS spec:
VERSION=version: Request version
REQUEST=GetMap: Request name
LAYERS=layer_list: Comma-separated list of one or more map layers. Optional if SLD parameter is present.
STYLES=style_list: Comma-separated list of one rendering style per requested layer. Optional if SLD parameter is present. NOTE that MapServer does not support named styles, so most times you would specify STYLES= with an empty value. MapServer does support STYLES when used with an SLD.
SRS=namespace:identifier: Spatial Reference System.
BBOX=minx,miny,maxx,maxy: Bounding box corners (lower left, upper right) in SRS units.
WIDTH=output_width: Width in pixels of map picture.
HEIGHT=output_height: Height in pixels of map picture.
FORMAT=output_format: Output format of map.
Remember when playing with valid WMS requests that BBOX is meaning the output extents and BBOX coordinates must suit the SRS.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: Alexandre.Laplante at statcan.gc.ca
Lähetetty: ma 15.6.2009 16:40
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: RE: [mapserver-users] Ignoring top level settings
Thanks Jukka,
But when I go directly to http://localhost/cgi-bin/mapserv.exe?map=../test/service/alex.map&service=WMS&version=1.1.1&layer=gcar&SRS=EPSG:42304&mode=map , the map looks identical no matter what I put in &SRS=EPSG:xxxxx
Right now the image is okay because my mapfile says the source projection is inverted. This makes it output the correct images, but the coordinates are all wrong, and I'm gonig to need to use correct coordinates.
Thanks again,
Alexandre Laplante
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Rahkonen Jukka
Sent: June 12, 2009 7:27 AM
To: Alexandre.Laplante at statcan.gc.ca; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Ignoring top level settings
Could it be so that OpenLayers inserts extents and projection in the request, and Mapserver gives what it is asked for? At least in normal WMS usage map level PROJECTION and EXTENT do not have an effect, Mapserver is sending the image in the requested projection, from a requested area.
-Jukka Rahkonen-
Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Alexandre.Laplante at statcan.gc.ca
Lähetetty: 11. kesäkuuta 2009 23:26
I I've discovered that the base layer rendering as jpg was a problem with my openlayers, not mapserver. However, I still can't change my top-level projection or extent. Any help is greatly appreciated.
Thank you.
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Alexandre.Laplante at statcan.gc.ca
Sent: June 8, 2009 9:35 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Ignoring top level settings
Hello list,
It seems as though my top level settings in my mapfile are being ignored. No matter what I put as projection, the output doesn't change (unless it's an invalid projection). Changing the values of EXTENT doesn't change anything either, as my map always starts zoomed out very far. I also have not been able to make my base layer output as anything other than jpg.
I have a feeling that this is related to an invalid /tmp/ location in the mapfile. I have not been able to write the location of the /tmp/ folder (it's on the root of my c: drive) in a way that mapserver will use it.
Apart from these things, everything works fine. I've been able to sort of counter-act the projection ignoring by telling mapserver that the layer's projection has lat_0=-49 when in fact, it is in epsg:43204 meaning lat_0=49.
I've attached my mapfile.
Thanks in advance,
Alexandre Laplante
Étudiant Co-op / Co-op Student
Division de l'Agriculture / Agriculture Division
Statistique Canada / Statistics Canada
170 Tunney's Pasture Driveway
Éd. Jean-Talon, 12è étage D1 / Jean-Talon Building, 12th floor D1
Ottawa, Ontario
<<alex.map>>
