[mapserver-users] Need help with ProxyPass configuration, please
cbrydon
carl.brydon at geonet-tech.com
Mon Jun 15 13:49:21 EDT 2009
Daniel,
What you suggest does work after all. The problem I was having is that the
IIS site
I was hitting was redirecting me to another IIS site that I did not have
setup in the
VirtualHost block. The settings you have below work great if AnotherTown is
a redirection
(if I can use that term) from SomeTown.
Appreciate your help!
Cheers,
Carl
Daniel Morissette wrote:
> cbrydon wrote:
>> I have also tried the following (among other configurations), but just
>> can't
>> seem to get thiings to work....
>> NameVirtualHost 111.111.111.111:80
>> # Apache Site
>> <VirtualHost 111.111.111.111:80>
>> DocumentRoot "/ms4w/Apache/htdocs"
>> ServerName 111.111.111.111
>> </VirtualHost>
>> # IIS Site
>> ServerName 111.111.111.111:80
>> DocumentRoot F:/Applications/2009/Custom/SomeTown
>> ProxyRequests OFF
>> ProxyPass / http://111.111.111.111:8080/
>> ProxyPassReverse / http://111.111.111.111:8080/
>> </VirtualHost>
>> The above code doesn't work either; it seems as though the 2nd virtual
>> host
>> isn't being recognized. SomeTown is actually in
>> F:/Applications/2009/Custom.
>> Below is the output of an error log file.
> Carl,
> You need a single VirtualHost for what you're trying to do. You have to
> decide which directories go to the proxy'd (IIS) server and list them
> there, and then let the local (MS4W) server handle the rest.
> For instance, if what you want is:
> http://111.111.111.111/SomeTown -> IIS
> http://111.111.111.111/AnotherTown -> IIS
> http://111.111.111.111/ (anything else) -> MS4W
> Then a config as follows should do the trick:
> # Apache Site
> # Forward some directories to the IIS server on port 8080
> # Anything not explicitly proxy'd here is expected to be local by default.
> ProxyPass /SomeTown http://111.111.111.111:8080/SomeTown
> ProxyPassReverse /SomeTown http://111.111.111.111:8080/SomeTown
> ProxyPass /AnotherTown http://111.111.111.111:8080/AnotherTown
> ProxyPassReverse /AnotherTown http://111.111.111.111:8080/AnotherTown
> </VirtualHost>
> I hope that helps
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
> mapserver-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Need-help-with-ProxyPass-configuration%2C-please-tp1972267p3081660.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
