[mapserver-users] output image is blank after a few runs of the
mapfile
Ishwari Sivagnanam
ishwari.s at gmail.com
Thu Jun 18 08:08:51 EDT 2009
Hello all,
I was experimenting with "Cartographic Symbol Construction with Mapserver".
I tried the line styles and the hatch symbol. The web page worked okay, all
layers were drawn and the symbols were great.
I used mapserver version 5.0.0 with Php Mapscript.
Layer with carto symbol style
#* layer definition main_quad1*
LAYER
NAME mainrd_qd
METADATA
"DESCRIPTION" "mainrd_w_index"
"GNAME" "geography Layers"
END
GROUP geo
TYPE LINE
STATUS OFF
DATA mainrd
CLASS
NAME "mnrd"
#TEMPLATE '/templates/Minor_RD_qry.html'
STYLE
COLOR 183 147 40
WIDTH 4
END
STYLE
COLOR 242 191 36
WIDTH 2
END
END
END # end layer main_quad1
This worked about 10 times and then the output image went blank. The web
page gives me no error, The scalebar for the output image is drawn, the
legend icons for the html legend are drawn but, none of the layers are
drawn in the output map image. I tried setting all the layers' "STATUS" to
"ON/DEFAULT" but that didn't fix it.
I tested the mapfile with the shp2img utility and I got the same blank ouput
image with only the scalebar in 5.0.0. Creating a new mapfile from scratch
with same styles etc seemed to fix the problem. But again after about 10
times of drawing the map the same issue came back.
I then tried the same mapfile with the shp2img utility in Mapserver 5.2 and
I get the same issue.
Any ideas on why is this happening? Has anybody ever run into this issue
before?
Thanks,
Ishwari
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090618/1de1692a/attachment.html
