RE: [mapserver-users] 5.x Tutorial on mapserv -v (raster doesn't work)
Lucena, Ivan
ivan.lucena at pmldnet.com
Thu Jun 18 10:41:15 EDT 2009
David,
That was it. I just add the world and everything started to work!
*SYMBOLSET*
# 1
Symbol
Name 'tent'
Type VECTOR
Filled TRUE
Points
0 1
.5 0
1 1
.75 1
.5 .5
.25 1
0 1
Thanks a lot.
Ivan
> -------Original Message-------
> From: Fawcett, David <David.Fawcett at state.mn.us>
> Subject: RE: [mapserver-users] 5.x Tutorial on mapserv -v (raster doesn't work)
> Sent: Jun 18 '09 09:21
> Ivan,
> You are likely running up against a change in requirements for map and
> symbol files that was implemented to improve security.
> Here is a description of what was done:
> http://mapserver.org/development/rfc/ms-rfc-56.html?highlight=symbolset
> The fix is easy. You just need to make sure that the first word in your
> symbolset file is 'SYMBOLSET'. There are similar requirements for map
> files and MapServer templates starting with 5.2.2. I am not sure if the
> key words are case-sensitive or not.
> David.
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Lucena,
> Ivan
> Sent: Thursday, June 18, 2009 9:05 AM
> To: mapserver-users
> Subject: [mapserver-users] 5.x Tutorial on mapserv -v (raster doesn't
> work)
> Hi there,
> I am using the MapServer distribution from OSGeo4w and the Totorial 5.x
> doesn't show the map in any raster or WMS examples.
> C:\OSGeo4W > mapserv -v
> MapServer version 5.2.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
> SUPPORTS=ICONV SUPPORTS =FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WF S_CLIENT SUPPORTS=WCS_SERVER
> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREA DS SUPPORTS=GEOS
> SUPPORTS=RGBA_PNG INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> I download the "tutorial.zip" by "Created by Pericles S. Nacionales Last
> updated: 20071020".
> I added that line on "C:\OSGeo4W\apache\conf\httpd.conf" :
> # parse MS4W apache conf files
> include "C:\ms4w/httpd.d/httpd_*.conf"
> The address "http://locahost/tutorial" works just fine. Like my Linux
> machine.
> But examples with raster and WMS doesn't.
> http://localhost/tutorial/example1-5.html
> http://localhost/tutorial/example1-6.html
> http://localhost/tutorial/example1-7.html
> http://localhost/tutorial/example1-8.html
> The rest of the sections and examples just return this error here:
> msLoadSymbolSet(): Unknown identifier. First token must be SYMBOLSET,
> this doesn't look like a symbol file.
> In C:\OSGeo4W\apache\logs\error.log there is no error message related to
> that.
> Does anyone know what could be wrong?
> Thanks in advance,
> Ivan
> mapserver-users at lists.osgeo.org
