[mapserver-users] New EPSG added but Projection Error
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Mon Jun 22 05:38:13 EDT 2009
Try adding some white space between <2054> and +proj
-Jukka Rahkonen-
stretch wrote:
Hi All
I have a requirement to create a map with a non-standard projection. I have
added the new projection to the /proj/nad/epsg file with the appropriate
parameters - i.e:
# Hartebeesthoek94 / Lo31
<2054>+proj=tmerc +lon_0=31 +datum=WGS84 <>
If I then try and reference that projection in my map file like below it
throws an error - msProcessProjection(): Projection library error.
projection not named:
PROJECTION
"init=epsg:2054"
END
On the other hand, if I reference the proj4 format directly - it works - i.e
PROJECTION
"+proj=tmerc +lon_0=31 +datum=WGS84"
END
Any ideas what I need to do, or is it not as simple as adding it directly to
the epsg file?
Thanks in advance
Andrew
View this message in context: http://n2.nabble.com/New-EPSG-added-but-Projection-Error-tp3131630p3131630.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
