[mapserver-users] Mapserver CGI 5.4 crashed my app (Windows 2003)
    stela anders
    stelaanders at gmail.com
    Mon Jun 22 07:22:16 PDT 2009
ok... I´m waiting for the news :p
Thanks
2009/6/18 Tamas Szekeres <szekerest at gmail.com>
> Hi,
> I've set it up (Win2003) but didn't crash, though I get blank images in cgi
> mode.
> http://vbkto.dyndns.org:1280/cgi-bin4/mapserv.exe?map=E
> :\tests\TestCGI\map.map&mode=map
> shp2img produces correct image however. I'm a bit uncertain whether the 2
> problems are the same but I'll look into this one in more detail shortly.
> Tamas
> 2009/6/18 stela anders <stelaanders at gmail.com>
>> Hi guys!
>> I got that binary now :
>> http://vbkto.dyndns.org:1280/sdk/release-1500-gdal-mapserver.zip
>> Same error Tamas...
>> System : Windows XP / IIS 5.1
>> Using Postgis as datasourse...
>> I made a package with :
>> - Mapfile
>> - Postgis data
>> - Html
>> You only need OL js to tryout...
>> Or you can try typing :
>> http://localhost/cgi-binx/mapserv.exe?map=map.map
>> The error is :
>> CGI Error
>> The specified CGI application misbehaved by not returning a complete set
>> of HTTP headers. The headers it did return are:
>> Using version 5.2.2 all works fine...
>> Stela
>> Hi,
>>> Some of the guys reported issues with mapserver 5.4+ in normal CGI mode
>>> (FastCGI was reported ok) but I couldn't reproduce it myself so it would be
>>> helpful if someone could describe the steps (and provide mapfiles/sample
>>> data) to check it out.
>>> You could also test with the binaries provided from here which appears to
>>> be working ok.
>>> http://vbkto.dyndns.org:1280/sdk/Default.aspx
>>> Best regards,
>>> Tamas
>>>>   Hey guys !
>>>> That´s my first message here... (I´m from Argentina, sorry about my bad
>>>> English)
>>>> Is there any bug on Mapserver 5.4 CGI ?
>>>> We have a full application using Mapserver 5.2 CGI on Windowns 2003/IIS
>>>> ... We tried to update to newest version 5.4 and got a CGI error ...
>>>> Is there any FAQ to upgrade ? Or maybe is it a bug?
>>>> Stela
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090622/951b9706/attachment.htm>
More information about the MapServer-users
