[mapserver-users] clipping symbols at tile boundary?
Wendell Turner
wendell at enflight.com
Mon Jun 22 13:54:13 EDT 2009
Thanks. The gutter parameter seems to fix the symbols, and
the symbol labels, but the labels on lines are still
chopped. The labelcache_map_edge_buffer didn't seem to
work. For now I'll just use 'singleTile: true', and take
the (non-tiled) performance hit.
On Mon, Jun 22, 2009 at 07:27:02AM -0400, Christy Nieman wrote:
> Hi,
> You can put "labelcache_map_edge_buffer" "-10" in the WEB block metadata.
> This will ensure that no labels are drawn within 10 pixels of a tile
> boundary (you can change the value to increase or decrease the buffer zone)
> E.g.:
> MAP
> WEB
> METADATA
> END
> END
> END
> Christy
> BrainDrain wrote:
>> OL gutter helps with symbols but breaks labels. PARTIALS false doesn't help
>> in this case. I didn't find solution how to avoid breaking labels while
>> using gutter. I suppose the only one is to turn off gutter (prebuild OL map
>> clone with no gutter) on scales when symbols are turned off (if symbols are
>> visible in large scales then labels uses large font size and gutter works
>> fine with labels).
>> Aaron Racicot wrote:
>>> Wendell,
>>> Look at 'gutter' in OpenLayers. It will allow you to get tiles slightly
>>> larger from your Mapserver WMS to get rid of some of the artifacts:
>>> http://dev.openlayers.org/docs/files/OpenLayers/Layer-js.html#OpenLayers.Lay
>>> er.gutter
>>> Hope that helps...
>>> Aaron
>>> Aaron Racicot
>>> Z-Pulley Inc.
>>> -----Original Message-----
>>> From: mapserver-users-bounces at lists.osgeo.org
>>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Wendell
>>> Turner
>>> Sent: Thursday, June 18, 2009 4:59 PM
>>> To: mapserver-users at lists.osgeo.org
>>> Subject: [mapserver-users] clipping symbols at tile boundary?
>>> (this must be basic, but here goes anyway...)
>>> I'm using Mapserver 5.2 with OpenLayers 2.7. I have a
>>> vector mapserver layer with point objects (shown with circle
>>> symbols) on it. The vector layer referenced via
>>> OpenLayers.Layer.WMS and is tiled.
>>> The circles are displayed in the tile that the center is on,
>>> but not the adjacent tiles. That is, if a circle is near
>>> the edge, part of the circle is chopped off.
>>> Is that what 'BUFFER 10' fixes? What about 'PARTIALS
>>> FALSE'? That seems to be just for labels, but that only
>>> shows the label when it completely lies within the tile.
>>> Do I need to turn off tiling completely?
>>> Thanks,
>>> Wendell
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
