[mapserver-users] Mapserver CGI 5.4 crashed my app (Windows 2003)
Tamas Szekeres
szekerest at gmail.com
Mon Jun 22 18:04:38 EDT 2009
Stela,
By using my latest binaries I've found that mapserv.exe is hanging right
after returning the image to the browser. This problem is possibly caused by
some breaking changes in geos 3-1, since geos 3-0 seems to be working
correctly. Would you test your application by using geos 3-0? I'd be curious
to know whether this problem is the same as yours, or not.
If you can't compile geos-3-0 then here is the dll compiled with MSVC2008.
http://vbkto.dyndns.org:1280/tests/geos_c.zip
Best regards,
Tamas
2009/6/22 stela anders <stelaanders at gmail.com>
> Log:
> 13:45:38 inetinfo.exe:5544 OPEN C:\Mapserver\cg-binx\mapserv.exe SUCCESS Options:
> Open Access: 001000A1
> Open Access: 00100001
> 13:45:38 inetinfo.exe:5544 QUERY
> INFORMATION C:\Mapserver\cg-binx\mapserv.exe SUCCESS FileInternalInformation
> 13:45:38 inetinfo.exe:5544 CLOSE C:\Mapserver\cg-binx\mapserv.exe SUCCESS
> INFORMATION C:\Mapserver\cg-binx\mapserv.exe SUCCESS Attributes: A
> INFORMATION C:\Mapserver\cg-binx\mapserv.exe SUCCESS Length: 33792
> 13:45:38 inetinfo.exe:5544 DIRECTORY C:\Mapserver\cg-binx\ SUCCESS FileBothDirectoryInformation:
> mapserv.exe
> 13:45:38 inetinfo.exe:5544 OPEN C:\Mapserver\cg-binx\mapserv.exe.Manifest NOT
> FOUND Options: Open Access: 001200A9
> FOUND Options: Open Access: 00100001
> 13:45:38 inetinfo.exe:5544 OPEN C:\Mapserver\cg-binx\mapserv.exe.Config NOT
> 13:45:38 mapserv.exe:1012 QUERY
> INFORMATION C:\Mapserver\cg-binx\mapserv.exe SUCCESS FileNameInformation
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\Prefetch\MAPSERV.EXE-0B3170C2.pf NOT
> FOUND Options: Open Access: Read
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\ SUCCESS Options: Open
> Directory Access: 00100020
> INFORMATION C:\Mapserver\cg-binx\libmap.dll SUCCESS Attributes: A
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libmap.dll SUCCESS Options:
> Open Access: 00100020
> INFORMATION C:\Mapserver\cg-binx\libmap.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\libmap.dll SUCCESS
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libmap.dll.2.Manifest NOT
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libmap.dll.2.Config NOT
> INFORMATION C:\Mapserver\cg-binx\zlib1.dll SUCCESS Attributes: A
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\zlib1.dll SUCCESS Options:
> INFORMATION C:\Mapserver\cg-binx\zlib1.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\zlib1.dll SUCCESS
> INFORMATION C:\Mapserver\cg-binx\mapserv.exe.Local\ NOT FOUND Attributes:
> Error
> INFORMATION C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e SUCCESS Attributes:
> D
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e SUCCESS Options:
> Open Directory Access: 00100020
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e\MSVCR90.dll SUCCESS Options:
> INFORMATION C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e\MSVCR90.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e\MSVCR90.dll SUCCESS
> INFORMATION C:\Mapserver\cg-binx\proj.dll SUCCESS Attributes: A
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\proj.dll SUCCESS Options:
> INFORMATION C:\Mapserver\cg-binx\proj.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\proj.dll SUCCESS
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\proj.dll.2.Manifest NOT
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\proj.dll.2.Config NOT
> Error
> D
> INFORMATION C:\Mapserver\cg-binx\libxml2.dll SUCCESS Attributes: A
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libxml2.dll SUCCESS Options:
> INFORMATION C:\Mapserver\cg-binx\libxml2.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\libxml2.dll SUCCESS
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libxml2.dll.2.Manifest NOT
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libxml2.dll.2.Config NOT
> INFORMATION C:\Mapserver\cg-binx\WSOCK32.dll NOT FOUND Attributes: Error
> INFORMATION C:\WINDOWS\system32\WSOCK32.dll SUCCESS Attributes: A
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\WSOCK32.dll SUCCESS Options:
> INFORMATION C:\WINDOWS\system32\WSOCK32.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\system32\WSOCK32.dll SUCCESS
> INFORMATION C:\Mapserver\cg-binx\WS2_32.dll NOT FOUND Attributes: Error
> INFORMATION C:\WINDOWS\system32\WS2_32.dll SUCCESS Attributes: A
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\WS2_32.dll SUCCESS Options:
> INFORMATION C:\WINDOWS\system32\WS2_32.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\system32\WS2_32.dll SUCCESS
> INFORMATION C:\Mapserver\cg-binx\WS2HELP.dll NOT FOUND Attributes: Error
> INFORMATION C:\WINDOWS\system32\WS2HELP.dll SUCCESS Attributes: A
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\WS2HELP.dll SUCCESS Options:
> INFORMATION C:\WINDOWS\system32\WS2HELP.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\system32\WS2HELP.dll SUCCESS
> INFORMATION C:\Mapserver\cg-binx\iconv.dll SUCCESS Attributes: A
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\iconv.dll SUCCESS Options:
> INFORMATION C:\Mapserver\cg-binx\iconv.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\iconv.dll SUCCESS
> Error
> D
> INFORMATION C:\Mapserver\cg-binx\libfcgi.dll SUCCESS Attributes: A
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libfcgi.dll SUCCESS Options:
> INFORMATION C:\Mapserver\cg-binx\libfcgi.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\libfcgi.dll SUCCESS
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libfcgi.dll.2.Manifest NOT
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libfcgi.dll.2.Config NOT
> Error
> D
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e\MSVCP90.dll SUCCESS Options:
> INFORMATION C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e\MSVCP90.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e\MSVCP90.dll SUCCESS
> INFORMATION C:\Mapserver\cg-binx\pdflib.dll SUCCESS Attributes: A
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\pdflib.dll SUCCESS Options:
> INFORMATION C:\Mapserver\cg-binx\pdflib.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\pdflib.dll SUCCESS
> INFORMATION C:\Mapserver\cg-binx\fribidi.dll SUCCESS Attributes: A
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\fribidi.dll SUCCESS Options:
> INFORMATION C:\Mapserver\cg-binx\fribidi.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\fribidi.dll SUCCESS
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\fribidi.dll.2.Manifest NOT
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\fribidi.dll.2.Config NOT
> Error
> D
> INFORMATION C:\Mapserver\cg-binx\LIBPQ.dll SUCCESS Attributes: A
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\LIBPQ.dll SUCCESS Options:
> INFORMATION C:\Mapserver\cg-binx\LIBPQ.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\LIBPQ.dll SUCCESS
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\LIBPQ.dll.2.Manifest NOT
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\LIBPQ.dll.2.Config NOT
> Error
> D
> INFORMATION C:\Mapserver\cg-binx\SHFOLDER.dll NOT FOUND Attributes: Error
> INFORMATION C:\WINDOWS\system32\SHFOLDER.dll SUCCESS Attributes: A
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\SHFOLDER.dll SUCCESS Options:
> INFORMATION C:\WINDOWS\system32\SHFOLDER.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\system32\SHFOLDER.dll SUCCESS
> INFORMATION C:\Mapserver\cg-binx\gdal17dev.dll SUCCESS Attributes: A
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\gdal17dev.dll SUCCESS Options:
> INFORMATION C:\Mapserver\cg-binx\gdal17dev.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\gdal17dev.dll SUCCESS
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\gdal17dev.dll.2.Manifest NOT
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\gdal17dev.dll.2.Config NOT
> INFORMATION C:\Mapserver\cg-binx\xerces-c_2_8.dll SUCCESS Attributes: A
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\xerces-c_2_8.dll SUCCESS Options:
> INFORMATION C:\Mapserver\cg-binx\xerces-c_2_8.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\xerces-c_2_8.dll SUCCESS
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\xerces-c_2_8.dll.2.Manifest NOT
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\xerces-c_2_8.dll.2.Config NOT
> Error
> D
> INFORMATION C:\Mapserver\cg-binx\libexpat.dll SUCCESS Attributes: A
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libexpat.dll SUCCESS Options:
> INFORMATION C:\Mapserver\cg-binx\libexpat.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\libexpat.dll SUCCESS
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libexpat.dll.2.Manifest NOT
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libexpat.dll.2.Config NOT
> Error
> D
> INFORMATION C:\Mapserver\cg-binx\ODBC32.dll NOT FOUND Attributes: Error
> INFORMATION C:\WINDOWS\system32\ODBC32.dll SUCCESS Attributes: A
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\ODBC32.dll SUCCESS Options:
> INFORMATION C:\WINDOWS\system32\ODBC32.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\system32\ODBC32.dll SUCCESS
> INFORMATION C:\Mapserver\cg-binx\sqlite3.dll SUCCESS Attributes: A
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\sqlite3.dll SUCCESS Options:
> INFORMATION C:\Mapserver\cg-binx\sqlite3.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\sqlite3.dll SUCCESS
> INFORMATION C:\Mapserver\cg-binx\geos_c.dll SUCCESS Attributes: A
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\geos_c.dll SUCCESS Options:
> INFORMATION C:\Mapserver\cg-binx\geos_c.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\geos_c.dll SUCCESS
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\geos_c.dll.2.Manifest NOT
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\geos_c.dll.2.Config NOT
> Error
> D
> INFORMATION C:\Mapserver\cg-binx\libcurl.dll SUCCESS Attributes: A
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libcurl.dll SUCCESS Options:
> INFORMATION C:\Mapserver\cg-binx\libcurl.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\libcurl.dll SUCCESS
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libcurl.dll.2.Manifest NOT
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\libcurl.dll.2.Config NOT
> Error
> D
> Error
> D
> Error
> D
> INFORMATION C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e\MSVCR90.dll SUCCESS Attributes:
> A
> 13:45:38 mapserv.exe:1012 OPEN C:\ SUCCESS Options: Open Directory Access:
> 00100001
> 13:45:38 mapserv.exe:1012 DIRECTORY C:\ SUCCESS FileBothDirectoryInformation:
> WINDOWS
> 13:45:38 mapserv.exe:1012 CLOSE C:\ SUCCESS
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\ SUCCESS Options: Open Directory
> Access: 00100001
> 13:45:38 mapserv.exe:1012 DIRECTORY C:\WINDOWS\ SUCCESS FileBothDirectoryInformation:
> WinSxS
> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\ SUCCESS
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e\ SUCCESS Options:
> Open Directory Access: 00100001
> 13:45:38 mapserv.exe:1012 DIRECTORY C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e\ SUCCESS FileBothDirectoryInformation:
> MSVCR90.dll
> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e\ SUCCESS
> INFORMATION C:\WINDOWS\system32\IMM32.DLL SUCCESS Attributes: A
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\IMM32.DLL SUCCESS Options:
> INFORMATION C:\WINDOWS\system32\IMM32.DLL SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\system32\IMM32.DLL SUCCESS
> INFORMATION C:\WINDOWS\system32\IMM32.DLL SUCCESS Length: 110080
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\COMCTL32.dll SUCCESS Options:
> INFORMATION C:\WINDOWS\system32\COMCTL32.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\system32\COMCTL32.dll SUCCESS
> INFORMATION C:\WINDOWS\system32\COMCTL32.dll SUCCESS Length: 617472
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\COMCTL32.dll.124.Manifest NOT
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\COMCTL32.dll.124.Config NOT
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\SHELL32.dll SUCCESS Options:
> INFORMATION C:\WINDOWS\system32\SHELL32.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\system32\SHELL32.dll SUCCESS
> INFORMATION C:\WINDOWS\system32\SHELL32.dll SUCCESS Length: 8491008
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\SHELL32.dll.124.Manifest NOT
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\SHELL32.dll.124.Config NOT
> Error
> INFORMATION C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83 SUCCESS Attributes:
> D
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83 SUCCESS Options:
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll SUCCESS Options:
> INFORMATION C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll SUCCESS
> INFORMATION C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll SUCCESS Length:
> 1054208
> INFORMATION C:\WINDOWS\WindowsShell.Manifest SUCCESS Attributes: RHA
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\WindowsShell.Manifest SUCCESS Options:
> INFORMATION C:\WINDOWS\WindowsShell.Manifest SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\WindowsShell.Manifest SUCCESS
> INFORMATION C:\WINDOWS\WindowsShell.Manifest SUCCESS Length: 749
> Open Access: Read
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\WindowsShell.Config NOT
> INFORMATION C:\WINDOWS\system32\odbcint.dll SUCCESS Attributes: A
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\odbcint.dll SUCCESS Options:
> INFORMATION C:\WINDOWS\system32\odbcint.dll SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\system32\odbcint.dll SUCCESS
> INFORMATION C:\WINDOWS\system32\odbcint.dll SUCCESS Length: 98304
> 13:45:38 mapserv.exe:1012 OPEN C:\MapServer\proj\nad \proj_def.dat PATH NOT
> 13:45:38 mapserv.exe:1012 OPEN C:\Mapserver\cg-binx\map.map SUCCESS Options:
> Open Access: Read
> INFORMATION C:\Mapserver\cg-binx\ SUCCESS FileNameInformation
> INFORMATION C:\Mapserver\cg-binx\map.map SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\Mapserver\cg-binx\map.map SUCCESS
> 13:45:38 mapserv.exe:1012 READ
> C:\Mapserver\cg-binx\map.map SUCCESS Offset: 0 Length: 8192
> 13:45:38 mapserv.exe:1012 READ C:\Mapserver\cg-binx\map.map END OF
> FILE Offset: 590 Length: 4096
> FILE Offset: 590 Length: 8192
> 13:45:38 mapserv.exe:1012 OPEN C:\MapServer\gdalplugins\ SUCCESS Options:
> 13:45:38 mapserv.exe:1012 DIRECTORY C:\MapServer\gdalplugins\ SUCCESS FileBothDirectoryInformation:
> 13:45:38 mapserv.exe:1012 DIRECTORY C:\MapServer\gdalplugins\ NO MORE
> FILES FileBothDirectoryInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\MapServer\gdalplugins\ SUCCESS
> INFORMATION C:\WINDOWS\system32\vsjitdebugger.exe SUCCESS Attributes: A
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\vsjitdebugger.exe SUCCESS Options:
> INFORMATION C:\WINDOWS\system32\vsjitdebugger.exe SUCCESS FileInternalInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\system32\vsjitdebugger.exe SUCCESS
> INFORMATION C:\WINDOWS\system32\vsjitdebugger.exe SUCCESS Length: 228872
> INFORMATION C:\WINDOWS\system32\vsjitdebugger.exe SUCCESS FileNameInformation
> 00100001
> WINDOWS
> Access: 00100001
> system32
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\vsjitdebugger.exe.Manifest NOT
> 13:45:38 mapserv.exe:1012 OPEN C:\WINDOWS\system32\vsjitdebugger.exe.Config NOT
> 13:45:38 vsjitdebugger.e:5636 QUERY
> INFORMATION C:\Mapserver\cg-binx\mapserv.exe BUFFER
> OVERFLOW FileNameInformation
> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83 SUCCESS
> 13:45:38 mapserv.exe:1012 CLOSE C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e SUCCESS
> 13:45:38 svchost.exe:860 OPEN C:\WINDOWS\Prefetch\MAPSERV.EXE-0B3170C2.pf NOT
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090623/540811c8/attachment-0001.html
