[mapserver-users] Re: Upgrading 5.2 -> 5.4 generating CGI error
on IIS(5.1 and 6.0) ... Possible BUG?
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Jun 23 10:55:08 EDT 2009
The next MS4W 3.0 beta will also be downgraded to geos-3.0.4 (you can
follow the progress at http://bugzilla.maptools.org/show_bug.cgi?id=2044)
-jeff
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
Tamas Szekeres wrote:
> Paul,
> The problem described in this thread sounds like it may be dedicated to
> a problem discovered recently in geos-3-1 branch causing the application
> to crash/hang during the process termination. You said you've been using
> MS4W 3.0 beta2 or the packages from
> http://vbkto.dyndns.org:1280/sdk/Default.aspx both have been using
> geos-3-1 in the packages up to this time.
> Since fastCGI keeps mapserv.exe running that would explain why this
> issue doesn't come up with the FCGI mode.
> I've now reverted to use geos-3-0 in the packages at
> Feel free to test with the recent versions and let me know about the
> details.
> Best regards,
> Tamas
