[mapserver-users] Compiling MapServer
Fawcett, David
David.Fawcett at state.mn.us
Tue Jun 23 12:02:56 EDT 2009
Perhaps libjpeg should be moved from the 'optional external libraries' to the 'required external libraries' section page of the docs then? http://mapserver.org/installation/unix.html
-----Original Message-----
From: Thomas Bonfort [mailto:thomas.bonfort at camptocamp.com]
Sent: Tuesday, June 23, 2009 10:59 AM
To: Frank Warmerdam
Cc: Fawcett, David; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Compiling MapServer
Frank,
We already had a dependency on libpng and libjpg through GD (as gd isn't statically linked against those). How can the direct dependency be causing any more problems than the actual situation ?
regards,
thomas
www.camptocamp.com
+33 4 79 26 57 97
On Tue, Jun 23, 2009 at 17:50, Frank Warmerdam<warmerdam at pobox.com> wrote:
> Fawcett, David wrote:
>> What is the latest advice for output image libraries when compiling
>> mapserv on unix? I remember an older conflict with libtiff and the
>> tiff functionality in GDAL.
>> If one is going to include GDAL, does it make sense to add libtiff,
>> libgeotiff, or libjpeg, or is it better practice to just use GDAL to
>> read and write these formats?
> David,
> It is better to leave out direct use of libtiff, and just let GDAL do
> it. Likewise for reading jpeg, and other image formats. However, I
> have noticed that mapserver-trunk now seems to depend on direct use of
> libpng and libjpeg for generating these files (as opposed to going
> through GD). So it may not be so easy to avoid libpng and libjpeg in
> builds.
> I persume this is not yet an issue with the released versions.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com light and sound - activate the windows |
> http://pobox.com/~warmerdam and watch the world go round - Rush |
> Geospatial Programmer for Rent
