[mapserver-users] WFS returning empty features
DeDuikertjes
DeDuikertjes at xs4all.nl
Wed Jun 24 09:39:39 EDT 2009
Bart,
Thanks, Tried to widen that. No luck ..
Is the request ok (i try in the browser)? :
http://tercera-go.tercera-ro.nl/cgi-bin/mapserv?map=../html/plancheck_test/data/80.101.100.35_check/NL.IMRO.0026.SVBBU-0001/wkt/NL.IMRO.0026.SVBBU-0001.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=getfeature&TYPENAME=geoidNL.IMRO.0026.SVBBU-0001_vlak
it returns:
<wfs:FeatureCollection xsi:schemaLocation="http://www.opengis.net/wfs
http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd
http://mapserver.gis.umn.edu/mapserver
http://tercera-go.tercera-ro.nl/cgi-bin/mapserv?map=../html/plancheck_test/data/80.101.100.35_check/NL.IMRO.0026.SVBBU-0001/wkt/NL.IMRO.0026.SVBBU-0001.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=geoidNL.IMRO.0026.SVBBU-0001_vlak&OUTPUTFORMAT=XMLSCHEMA">
<gml:boundedBy>
<gml:Box srsName="EPSG:28992">
<gml:coordinates>
155065.290000,467655.922000 156442.422000,470040.750000
</gml:coordinates>
</gml:Box>
</gml:boundedBy>
</wfs:FeatureCollection>
On closer inspection uDig does something strange. On zoom to layer it
zooms to the wrong area (but shows no features there either).
MArco
bartvde at osgis.nl schreef:
> Try and widen your MAP->EXTENT.
> Best regards,
> Bart
>> Roy, Jukka, List,
>> I've tried adding extents to each layer: no succes
>> I've
>> "gml_include_items" "all"
>> "gml_featureid" "geoidn"
>> in the layer metadata
>> MArco
>> Here is a snippet of the mapfile:
>> MAP
>> NAME "NL.IMRO.0026.SVBBU-0001"
>> IMAGETYPE png
>> UNITS METERS
>> EXTENT 155016 467631 156758 470080
>> PROJECTION
>> "init=epsg:28992"
>> END
>> WEB
>> METADATA
>> "ows_title" "NL.IMRO.0026.SVBBU-0001"
>> "wms_onlineresource"
>> "http://tercera-go.tercera-ro.nl/cgi-bin/mapserv?map=../html/plancheck_test/data/80.101.100.35_check/NL.IMRO.0026.SVBBU-0001/wkt/NL.IMRO.0026.SVBBU-0001.map&"
>> "wfs_onlineresource"
>> "wfs_srs" "EPSG:28992"
>> "wms_srs" "EPSG:28992"
>> END
>> END
>> LAYER
>> name "geoidNL.IMRO.0026.SVBBU-0001_vlak"
>> GROUP "geoidNL.IMRO.0026.SVBBU-0001"
>> PROJECTION
>> "init=epsg:28992"
>> END
>> METADATA
>> "ows_group_title" "geoidNL.IMRO.0026.SVBBU-0001"
>> "ows_title" "geoidNL.IMRO.0026.SVBBU-0001_vlak"
>> END
>> STATUS off
>> TYPE polygon
>> DUMP true
>> CONNECTIONTYPE postgis
>> CONNECTION "host=localhost user=tc_check dbname=80.101.100.35"
>> DATA 'tc_vlak_geometry from "NL.IMRO.0026.SVBBU-0001" using unique
>> geoidn using srid=28992'
>> FILTER "geoidn='geoidNL.IMRO.0026.SVBBU-0001'"
>> OPACITY 30
>> TEMPLATE "dummy.html"
>> CLASS
>> STYLE
>> COLOR 0 0 0
>> OUTLINECOLOR 255 0 0
>> END
>> END
>> END
>> Rahkonen Jukka schreef:
>>> Hi,
>>> Do you have something in "gml_include_items" in the layer metadata?
>>> -Jukka Rahkonen-
>>> DeDuikertjes wrote:
>>> Roy, List,
>>> i'm using MapServer version 5.1-dev
>>> I've set the map extent. I did not set layer extents. Is that necessary?
>>> MArco
>>> Roy Braam schreef:
>>>> What version of mapserver are you using? Have you set the map extent
>>>> and layer extents?
>>>> Roy
>>>> _____
>>>> From: DeDuikertjes [mailto:DeDuikertjes at xs4all.nl]
>>>> To: mapserver-users at lists.osgeo.org
>>>> Sent: Wed, 24 Jun 2009 15:12:29 +0200
>>>> Subject: [mapserver-users] WFS returning empty features
>>>> Dear List,
>>>> I've mapserver all set up.
>>>> The mapfile is working and produces a nice and working WMS.
>>>> The WFS is giving me troubles.
>>>> It returns a valid capabilities document with no warnings
>>>> A getfeature request returns GML, with the bounds defined, but
>>>> otherwise
>>>> with NO features.
>>>> This for a layer which draws perfectly well in the WMS.
>>>> uDig sees all colums (attributes) of the layer, but every column is
>>>> empty.
>>>> I've not a clue what I am doing wrong.
>>>> any help greatly appreciated.
>>>> MArco
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
