[mapserver-users] WFS returning empty features
DeDuikertjes
DeDuikertjes at xs4all.nl
Wed Jun 24 09:46:56 EDT 2009
Bart, List,
Removed Filter tag. No succes.
MArco
bartvde at osgis.nl schreef:
> Hmm, running out of ideas :-)
> What if you remove your FILTER tag or add brackets to it?
> FILTER "(geoidn='geoidNL.IMRO.0026.SVBBU-0001')"
> Best regards,
> Bart
>> Bart,
>> Thanks, Tried to widen that. No luck ..
>> Is the request ok (i try in the browser)? :
>> http://tercera-go.tercera-ro.nl/cgi-bin/mapserv?map=../html/plancheck_test/data/80.101.100.35_check/NL.IMRO.0026.SVBBU-0001/wkt/NL.IMRO.0026.SVBBU-0001.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=getfeature&TYPENAME=geoidNL.IMRO.0026.SVBBU-0001_vlak
>> it returns:
>> <wfs:FeatureCollection xsi:schemaLocation="http://www.opengis.net/wfs
>> http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd
>> http://mapserver.gis.umn.edu/mapserver
>> http://tercera-go.tercera-ro.nl/cgi-bin/mapserv?map=../html/plancheck_test/data/80.101.100.35_check/NL.IMRO.0026.SVBBU-0001/wkt/NL.IMRO.0026.SVBBU-0001.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=geoidNL.IMRO.0026.SVBBU-0001_vlak&OUTPUTFORMAT=XMLSCHEMA">
>> <gml:boundedBy>
>> <gml:Box srsName="EPSG:28992">
>> <gml:coordinates>
>> 155065.290000,467655.922000 156442.422000,470040.750000
>> </gml:coordinates>
>> </gml:Box>
>> </gml:boundedBy>
>> </wfs:FeatureCollection>
>> On closer inspection uDig does something strange. On zoom to layer it
>> zooms to the wrong area (but shows no features there either).
>> MArco
>>> Try and widen your MAP->EXTENT.
>>> Best regards,
>>> Bart
>>>> Roy, Jukka, List,
>>>> I've tried adding extents to each layer: no succes
>>>> I've
>>>> "gml_include_items" "all"
>>>> "gml_featureid" "geoidn"
>>>> in the layer metadata
>>>> MArco
>>>> Here is a snippet of the mapfile:
>>>> MAP
>>>> NAME "NL.IMRO.0026.SVBBU-0001"
>>>> IMAGETYPE png
>>>> UNITS METERS
>>>> EXTENT 155016 467631 156758 470080
>>>> PROJECTION
>>>> "init=epsg:28992"
>>>> END
>>>> WEB
>>>> METADATA
>>>> "ows_title" "NL.IMRO.0026.SVBBU-0001"
>>>> "wms_onlineresource"
>>>> "http://tercera-go.tercera-ro.nl/cgi-bin/mapserv?map=../html/plancheck_test/data/80.101.100.35_check/NL.IMRO.0026.SVBBU-0001/wkt/NL.IMRO.0026.SVBBU-0001.map&"
>>>> "wfs_onlineresource"
>>>> "wfs_srs" "EPSG:28992"
>>>> "wms_srs" "EPSG:28992"
>>>> END
>>>> END
>>>> LAYER
>>>> name "geoidNL.IMRO.0026.SVBBU-0001_vlak"
>>>> GROUP "geoidNL.IMRO.0026.SVBBU-0001"
>>>> PROJECTION
>>>> "init=epsg:28992"
>>>> END
>>>> METADATA
>>>> "ows_group_title" "geoidNL.IMRO.0026.SVBBU-0001"
>>>> "ows_title" "geoidNL.IMRO.0026.SVBBU-0001_vlak"
>>>> END
>>>> STATUS off
>>>> TYPE polygon
>>>> DUMP true
>>>> CONNECTIONTYPE postgis
>>>> CONNECTION "host=localhost user=tc_check dbname=80.101.100.35"
>>>> DATA 'tc_vlak_geometry from "NL.IMRO.0026.SVBBU-0001" using unique
>>>> geoidn using srid=28992'
>>>> FILTER "geoidn='geoidNL.IMRO.0026.SVBBU-0001'"
>>>> OPACITY 30
>>>> TEMPLATE "dummy.html"
>>>> CLASS
>>>> STYLE
>>>> COLOR 0 0 0
>>>> OUTLINECOLOR 255 0 0
>>>> END
>>>> END
>>>> END
>>>> Rahkonen Jukka schreef:
>>>>> Hi,
>>>>> Do you have something in "gml_include_items" in the layer metadata?
>>>>> -Jukka Rahkonen-
>>>>> DeDuikertjes wrote:
>>>>> Roy, List,
>>>>> i'm using MapServer version 5.1-dev
>>>>> I've set the map extent. I did not set layer extents. Is that
>>>>> necessary?
>>>>> MArco
>>>>> Roy Braam schreef:
>>>>>> What version of mapserver are you using? Have you set the map extent
>>>>>> and layer extents?
>>>>>> Roy
>>>>>> _____
>>>>>> From: DeDuikertjes [mailto:DeDuikertjes at xs4all.nl]
>>>>>> To: mapserver-users at lists.osgeo.org
>>>>>> Sent: Wed, 24 Jun 2009 15:12:29 +0200
>>>>>> Subject: [mapserver-users] WFS returning empty features
>>>>>> Dear List,
>>>>>> I've mapserver all set up.
>>>>>> The mapfile is working and produces a nice and working WMS.
>>>>>> The WFS is giving me troubles.
>>>>>> It returns a valid capabilities document with no warnings
>>>>>> A getfeature request returns GML, with the bounds defined, but
>>>>>> otherwise
>>>>>> with NO features.
>>>>>> This for a layer which draws perfectly well in the WMS.
>>>>>> uDig sees all colums (attributes) of the layer, but every column is
>>>>>> empty.
>>>>>> I've not a clue what I am doing wrong.
>>>>>> any help greatly appreciated.
>>>>>> MArco
>>>>>> _______________________________________________
>>>>>> mapserver-users mailing list
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
