[mapserver-users] Non-conformant behaviour with MapServer 5.4 WMS 1.3.0 GetCapabilities response?
Passmore, James H
jpass at bgs.ac.uk
Wed Jun 24 08:08:24 PDT 2009
Hi Tom,
Thanks for your speedy response
> Can you send along an example mapfile / snippet?
My Mapfile begins:
MAP
NAME "ONEGEOLOGY"
STATUS on
SIZE 800 400
EXTENT 59.7812 26.9152 75.5985 40.9476
UNITS dd
SHAPEPATH "data"
IMAGECOLOR 255 255 255
IMAGETYPE png
RESOLUTION 96
PROJECTION
# we created a file 'crs' put in the nad folder and copied the epsg 4326 content from the epsg file
"init=crs:84"
#"proj=longlat"
#"ellps=WGS84"
#"datum=WGS84"
#"no_defs"
END #projection
DEBUG on
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGBA
EXTENSION "png"
END
WEB
HEADER "myheader..."
FOOTER "myfooter..."
IMAGEPATH "mypath..."
IMAGEURL "myvirtualdir..."
LOG "pathtolog"
METADATA
MAX_EXTENTS "59.443 26.4857 75.7411 41.2513"
OWS_TITLE "AGS Bedrock and Structural geology"
OWS_ABSTRACT "AGS 1:1 million scale Bedrock and Structural geology of Afghanistan"
OWS_KEYWORDLIST "OneGeology,geology,map,Afghanistan,bedrock,structural,faults,age"
OWS_CONTACTPERSON "The Director General"
OWS_CONTACTORGANIZATION "Afghanistan Geological Survey"
OWS_ADDRESSTYPE "postal"
OWS_ADDRESS "Afghanistan Geological Survey building, next to slaughter house, Jalalabad road"
OWS_CITY "Kabul"
OWS_STATEORPROVINCE "Kabul"
OWS_POSTCODE "District 9"
OWS_COUNTRY "Afghanistan"
OWS_FEES "none"
OWS_ACCESSCONSTRAINTS "The 1:1,000,000 map data is available for free download for your personal, teaching, research or non-commercial use. Your use of any information provided by the Afghanistan Geological Survey (AGS) is at your own risk. The AGS gives no warranty, condition or representation as to the quality, accuracy or completeness of the information or its suitability for any use or purpose. All implied conditions relating to the quality or suitability of the information, and all liabilities arising from the supply of the information (including any liability arising in negligence) are excluded to the fullest extent permitted by law."
OWS_FEATURE_INFO_MIME_TYPE "text/html"
OWS_SRS "CRS:84 EPSG:32641 EPSG:32642 EPSG:32643"
END #metadata
END #web
LEGEND
OUTLINECOLOR 200 200 200
KEYSPACING 10 10
LABEL
TYPE bitmap
SIZE small
END #Label
END #Legend
LAYER
NAME "AFG_AGS_1M_BLS"
GROUP "Bedrock"
DATA "1MgeolbyLCe4326"
TYPE polygon
STATUS off
#TRANSPARENCY 100
OPACITY 100
TOLERANCE 0
TOLERANCEUNITS pixels
TRANSFORM true
DUMP true # return GML format
HEADER "mypath..."
TEMPLATE "mypath..."
PROJECTION
"proj=longlat"
"ellps=WGS84"
"datum=WGS84"
"no_defs"
END #projection
METADATA
GML_INCLUDE_ITEMS "L_CODE"
GML_FEATUREID "GID"
OWS_TITLE "AFG AGS 1:1M Bedrock Lithostratigraphy"
The GetCapabilities response is:
http://194.66.252.156/cgi-bin/AGS_Bedrock_and_Structural_Geology/wms?service=WMS&version=1.3.0&request=GetCapabilities&
>Out of interest, can you elaborate on why EX_GeographicBoundingBox is
>not suitable, given the implicity of the CRS?
Well, I'm not sure why the OGC standard states this requirement, and there is probably more than one reason, however I'm guessing that if at least one BoundingBox is required, we should assume that WMS conformant clients might expect it, and then error if it doesn't exist. More importantly, what happens if I don't want to use CRS:84 but some other projection?
> You can always write a MapScript WxS wrapper (see
> http://www.mapserver.org/ogc/mapscript.html) to create custom
> Capabilities XML as per your requirements, as an interim workaround.
Thanks
James
This message (and any attachments) is for the recipient only. NERC
is subject to the Freedom of Information Act 2000 and the contents
of this email and any reply you make may be disclosed by NERC unless
it is exempt from release under the Act. Any material supplied to
NERC may be stored in an electronic records management system.
More information about the MapServer-users
