[mapserver-users] display an imagery
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Jun 24 17:46:00 EDT 2009
Start from a simple case, make it to work and add more features afterwords. Some suggestions:
- Use just one image in the beginning instead of tileindex
- Check the extents and projection of the image with gdalinfo
- Start with using the same projection as input and output
- Use absolute path to image
- Add DEBUG to layer definitions
- Test with shp2img
By a quick look these setting cannot be right (projection and extents do not suit):
EXTENT 2445459.07136253 7001896.96486324 2514178.54806653
7070616.44156724
UNITS FEET
PROJECTION
"init=epsg:4326"
-Jukka Rahkonen-
Suman Chatterjee
Hi all,
I am trying to display an imagery with mapserver. But I am not able to
see the image. My Mapfile is as shown:
# Start of map file
MAP
NAME ADDISON
STATUS ON
SIZE 600 600
7070616.44156724
UNITS FEET
SHAPEPATH "C:/ms4w/Apache/htdocs/mapservertest/data"
IMAGECOLOR 255 255 255
TEMPLATEPATTERN "addison"
PROJECTION
"init=epsg:4326"
END
OUTPUTFORMAT
NAME png
DRIVER "AGG/PNG"
IMAGEMODE RGBA
EXTENSION "png"
END
WEB
# HEADER templates/header.html
TEMPLATE "set in index.html"
MINSCALE 1000
MAXSCALE 1550000
IMAGEPATH "c:/ms4w/Apache/htdocs/test/"
IMAGEURL "/test/"
END
LAYER
NAME "hpool"
TYPE RASTER
STATUS ON
TILEINDEX "ras_index.shp"
TILEITEM "location"
PROCESSING "BANDS=4,2,1"
PROCESSING "SCALE=AUTO"
END
END
If anybody can help me in getting the RASTER to work that will be great.
Thanks
Suman
This e-mail and any files or attachments transmitted with it contains Information that is confidential and privileged. This document may contain Protected Health Information (PHI) or other information that is intended only for the use of the individual(s) and entity(ies) to whom it is addressed. If you are the intended recipient, further disclosures are prohibited without proper authorization. If you are not the intended recipient, any disclosure, copying, printing, or use of this information is strictly prohibited and possibly a violation of federal or state law and regulations. If you have received this information in error, please delete it and notify Hamid Khaleghipour at 972-450-2868 immediately. Thank you.
