[mapserver-users] javascript query template examples
Wendell Turner
wendell at enflight.com
Thu Jun 25 17:59:16 EDT 2009
On Thu, Jun 25, 2009 at 03:13:21PM -0500, Steve Lime wrote:
> Here's one example using new-style templating (recommend
> MapServer 5.4.1).
I'm using 5.2.0. Do I need to upgrade?
> Anyway, please ask questions if you need to.
Ok!
> The TEMPLATE:
> // MapServer Template
> function updateCountyList(element) {
> var option;
So, where does this template go?
1) there is a TEMPLATE in the WEB section. It seems that if
that line is present, it gets used. I don't think it is
that template.
2) There is DRIVER 'TEMPLATE' in the OUTPUTFORMAT section.
Should the above code be in a file named TEMPLATE?
3) There is a file in the FORMATOPTION under a /templates/
directory that looks suspicious.
4) There is a TEMPLATE in the LAYER section that is used to
indicate that the layer is queryable, and how to format that
layer's data.
> The OUTPUTFORMAT:
> OUTPUTFORMAT
> NAME 'county_select_list'
> DRIVER 'TEMPLATE'
> MIMETYPE 'text/javascript'
> FORMATOPTION 'ATTACHMENT=county_select_list.js'
> FORMATOPTION 'FILE=/templates/demo_county_select_list.js'
> END
What is the difference in ATTACHMENT and FILE?
> The call to the CGI to run it is:
> <script src="http://maps.dnr.state.mn.us/cgi-bin/mapserv54?map=demo.map&qlayer=counties&qformat=county_select_list&mode=nquery"></script>
Aha! qformat=name_of_the_output_format
Thanks,
Wendell
