[mapserver-users] Spatial queries to Mapserver
Gabriel Messner
gabmessner at gmail.com
Fri Jun 26 07:51:43 EDT 2009
Thanks, I´ll digest it :-)
2009/6/26 Ben Madin <ben at remoteinformation.com.au>
> Gabriel,
> You need to add a layer with your query in it - you can use variable
> substitution etc.
> an example (may or may not be a good one!) :
> LAYER
> DEBUG 3
> NAME "buffalo"
> GROUP "Movement"
> METADATA
> layer_title "Buffalo"
> layer_order "2"
> END
> CONNECTIONTYPE postgis
> CONNECTION "host=localhost port=5432 dbname=prices"
> PROCESSING "CLOSE_CONNECTION=DEFER"
> DATA "route FROM (
> SELECT s.id, s.commodity, s.shortname, s.amount,
> s.purpose, s.origprov, s.destprov, ST_MakeLine(s.startpoint, s.endpoint) as
> route, to_char(s.origindate,'DD/MM/YYYY') as date
> FROM (
> SELECT m.id, c.commodity, sp.shortname, c.amount,
> r.name AS purpose,
> initcap(o.name) as origprov, initcap(d.name) as
> destprov,
> ST_Centroid(o.geom) as startpoint,
> ST_Centroid(d.geom) as endpoint, origindate
> FROM movements m
> LEFT OUTER JOIN locations o
> ON m.originprovince = o.hiercode
> AND o.del = 0
> AND o.level = 2
> LEFT OUTER JOIN locations d
> ON m.destinationprovince = d.hiercode
> AND d.del = 0
> AND d.level = 2
> JOIN commodities c
> ON m.id = c.movementid
> AND c.del = 0
> AND c.commodity = 2
> LEFT OUTER JOIN species sp
> ON c.commodity = sp.id
> AND sp.del = 0
> LEFT OUTER JOIN reasons r
> ON c.purpose::int = r.id
> AND r.del = 0
> WHERE m.del = 0
> AND originprovince is not null
> AND originprovince not like '0'
> AND destinationprovince is not null
> AND destinationprovince not like '0'
> ) AS s
> WHERE s.origindate > '%start%'
> AND s.origindate < '%end%'
> ORDER BY s.origindate
> ) AS foo USING UNIQUE id USING srid=4326"
> TYPE LINE
> STATUS ON
> HEADER 'templates/trade_header.html'
> FOOTER 'templates/trade_footer.html'
> CLASSITEM commodity
> CLASS
> NAME "Buffalo"
> EXPRESSION "2"
> STYLE
> SYMBOL "arrow1"
> OFFSET 0 0
> SIZE 12
> COLOR 0 0 255
> END
> TEMPLATE 'templates/trade_query.html'
> END
> END
> Actually, I don't think it's a great example, but it shows you how to
> create a line on the fly using the centroid (probably should have been point
> on surface) showing the direction the animals moved, within a user specified
> time frame.
> I'm open to any feedback on this - it's a modification of one I modified
> from one Regina Obe posted somewhere.
> I should say, note the use of debug. the error messages are invaluable when
> it doesn't work.
> good luck
> cheers
> Ben
> On 26/06/2009, at 2:47 PM, mapserver-users-request at lists.osgeo.org wrote:
> *Subject: **[mapserver-users] Spatial queries to Mapserver*
> Hi all,
> Any one know of examples about how to call spatial queries using Postis
> functions from Mapserver?
> Ben Madin
> REMOTE INFORMATION
> t : +61 8 9192 5455
> f : +61 8 9192 5535
> m : 0448 887 220
> Broome WA 6725
> Out here, it pays to know...
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090626/ea41a58e/attachment.html
