[mapserver-users] getfeatureinfo problems
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Fri Jun 26 09:10:12 EDT 2009
Mapserver needs an integer type column for the USING UNIQUE clause, not
a string column. That won't work.
Best regards,
Bart
DeDuikertjes wrote:
> Jukka,
> Thank you, I've tried the SQL statement:
> DECLARE mycursor BINARY CURSOR FOR SELECT
> asbinary(force_collection(force_2d(tc_vlak_geometry)),'NDR'),geoidn::text
> from "NL.IMRO.0026.SVBBU-0001" WHERE
> (geoidn='geoidNL.IMRO.0026.SVBBU-0001') and (tc_vlak_geometry &&
> setSRID( 'BOX3D(155984.407968748 468982.233317728,156024.590926508
> 469022.416275488)'::BOX3D,28992) )
> with the first DECLARE part omitted, so:
> SELECT
> This returns two rows.
> I've tried
> SELECT
> "geoidn"::text,"idealisatie"::text,"tc_multi_geometry"::text,"tc_lijn_geometry"::text,"tc_punt_geometry"::text,asbinary(force_collection(force_2d(tc_vlak_geometry)),'NDR')
> from "NL.IMRO.0026.SVBBU-0001" WHERE geoidn = 0
> also, which returns 0 rows.
> This is as expected from this query as it asks for WHERE geoidn = 0
> geoidn never is 0.
> Why does mapserver come to this query? I've never asked for geidn to
> be zero!
> If I remove the WHERE geoidn = 0 I get a result for all the layers on
> the point (all the layers in fact).
> Somehow this WHERE geoidn = 0 condition is constructed false. Ist
> should be something like WHERE geoidn = geoidNL.IMRO.0026.SVBBU-0001
> I've not a clue where that wrong query clause comes from.
> MArco
> P.S. In earlier attempts I've renamed the tables with identical results.
> Rahkonen Jukka schreef:
>> Hi,
>> Have you tried to run the SQL queries from logfile directly? I
>> wonder if for example this part is correct and finds any data:
>> WHERE (geoidn='geoidNL.IMRO.0026.SVBBU-0001') and (tc_vlak_geometry
>> && setSRID( 'BOX3D(155984.407968748 468982.233317728,156024.590926508
>> Just a guess, but perhaps odd table name makes some trouble. How
>> about reneming or copying the table temporarily to something wiht
>> more simple name, like "test"?
>> -Jukka Rahkonen-
>> DeDuikertjes wrote:
>> Dear list,
>> yesterday I reported problems with my WFS server. I could not fix
>> that up till now.
>> I have another possibly related problem.
>> My WMS is set up allright, getcapabilities is ok, I can see the map,
>> pan zoom, etc, no problems.
>> When I do an Identify (GetFeatureInfo request), I get back an
>> exception-report, with no items in (so essentially an ampty exception
>> report).
>> The query just doesn't seem to find the data.
>> Clicking inside a feature and outside does differ (outside doesn't
>> give an exception report).
>> I've enabled debugging and this is the output when I do a
>> GetFeatureInfo request:
>> [Fri Jun 26 13:21:11 2009].498623 CGI Request 1 on process 1525
>> [Fri Jun 26 13:21:11 2009].518710 msPOSTGISLayerOpen called
>> datastatement: tc_vlak_geometry from "NL.IMRO.0026.SVBBU-0001" using
>> unique geoidn using srid=28992
>> [Fri Jun 26 13:21:11 2009].518735 MSPOSTGISLayerOpen -- shared
>> connection not available.
>> [Fri Jun 26 13:21:11 2009].523422
>> msConnPoolRegister(geoidNL.IMRO.0026.SVBBU-0001_vlak,host=localhost
>> user=tc_check dbname=80.101.100.35,0x9457b38)
>> [Fri Jun 26 13:21:11 2009].523453 msPOSTGISLayerFreeItemInfo called
>> [Fri Jun 26 13:21:11 2009].523466 msPOSTGISLayerWhichShapes called
>> [Fri Jun 26 13:21:11 2009].523490 msPOSTGISLayerParseData: unique
>> column = geoidn, srid='28992', geom_column_name = tc_vlak_geometry,
>> table_name="NL.IMRO.0026.SVBBU-0001"
>> [Fri Jun 26 13:21:11 2009].523796 query_string_0_6:DECLARE mycursor
>> [Fri Jun 26 13:21:11 2009].535912 msPOSTGISLayerFreeItemInfo called
>> [Fri Jun 26 13:21:11 2009].535925 msPOSTGISLayerClose datastatement:
>> tc_vlak_geometry from "NL.IMRO.0026.SVBBU-0001" using unique geoidn
>> using srid=28992
>> [Fri Jun 26 13:21:11 2009].535931 msPOSTGISLayerClose -- closing
>> query_result
>> [Fri Jun 26 13:21:11 2009].536007
>> msConnPoolRelease(geoidNL.IMRO.0026.SVBBU-0001_vlak,host=localhost
>> [Fri Jun 26 13:21:11 2009].536017 msConnPoolClose(host=localhost
>> [Fri Jun 26 13:21:11 2009].538905 msPOSTGISLayerOpen called
>> [Fri Jun 26 13:21:11 2009].538914 MSPOSTGISLayerOpen -- shared
>> [Fri Jun 26 13:21:11 2009].543298
>> [Fri Jun 26 13:21:11 2009].543314 msPOSTGISLayerFreeItemInfo called
>> [Fri Jun 26 13:21:11 2009].543319 in msPOSTGISLayerGetItems (find
>> column names)
>> [Fri Jun 26 13:21:11 2009].543329 msPOSTGISLayerParseData: unique
>> [Fri Jun 26 13:21:11 2009].545217 msPOSTGISLayerInitItemInfo called
>> [Fri Jun 26 13:21:11 2009].545230 msPOSTGISLayerGetShape called for
>> record = 0
>> [Fri Jun 26 13:21:11 2009].545239 msPOSTGISLayerParseData: unique
>> [Fri Jun 26 13:21:11 2009].545253 msPOSTGISLayerGetShape: DECLARE
>> mycursor2 BINARY CURSOR FOR SELECT
>> from "NL.IMRO.0026.SVBBU-0001" WHERE geoidn = 0 [Fri Jun 26 13:21:11
>> 2009].547105 msFreeMap(): freeing map at 0x943d518.
>> [Fri Jun 26 13:21:11 2009].547114 msPOSTGISLayerClose datastatement:
>> using srid=28992
>> [Fri Jun 26 13:21:11 2009].547119 msPOSTGISLayerClose -- query_result
>> is NULL
>> [Fri Jun 26 13:21:11 2009].547124
>> Just as with the WFS problem, there is no data returning. The WFS
>> does show the exposed columns, never any data in.
>> I've not a clue of how to proceed, or how to get extra debug info.
>> Please help !
>> MArco
>> [Fri Jun 26 13:21:11 2009].547132 msConnPoolClose(host=localhost
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
