[mapserver-users] Spatial queries to Mapserver
Ben Madin
ben at remoteinformation.com.au
Sun Jun 28 01:17:19 EDT 2009
Thanks Dan,
Could you elaborate on this - there are a username and password on the
database layer for select only for web user, but I scrubbed them from
my post - which was remiss of me but I was in a hurry.
However, is there a way in MapServer to "clean" the parameters that I
have used - I could imagine a startdate like 12';DELETE from
movements; is what you mean by sql injection?
cheers
Ben
On 27/06/2009, at 10:39 PM, mapserver-users-request at lists.osgeo.org
wrote:
> From: Dan Little <danlittle at yahoo.com>
> Date: 27 June 2009 10:32:58 PM
> To: Gabriel Messner <gabmessner at gmail.com>, mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Spatial queries to Mapserver
> Make sure your user has limited table access. This example would
> allow for SQL injection.
> From: Gabriel Messner <gabmessner at gmail.com>
> To: mapserver-users at lists.osgeo.org
> Sent: Friday, June 26, 2009 6:51:43 AM
> Thanks, I´ll digest it :-)
> 2009/6/26 Ben Madin <ben at remoteinformation.com.au>
> Gabriel,
> You need to add a layer with your query in it - you can use variable
> substitution etc.
> an example (may or may not be a good one!) :
> LAYER
> DEBUG 3
> NAME "buffalo"
> GROUP "Movement"
> METADATA
> layer_title "Buffalo"
> layer_order "2"
> END
> CONNECTIONTYPE postgis
> CONNECTION "host=localhost port=5432 dbname=prices"
> PROCESSING "CLOSE_CONNECTION=DEFER"
> DATA "route FROM (
> SELECT s.id, s.commodity, s.shortname, s.amount,
> s.purpose, s.origprov, s.destprov, ST_MakeLine(s.startpoint,
> s.endpoint) as route, to_char(s.origindate,'DD/MM/YYYY') as date
> FROM (
> SELECT m.id, c.commodity, sp.shortname,
> c.amount, r.name AS purpose,
> initcap(o.name) as origprov, initcap(d.name)
> as destprov,
> ST_Centroid(o.geom) as startpoint,
> ST_Centroid(d.geom) as endpoint, origindate
> FROM movements m
> LEFT OUTER JOIN locations o
> ON m.originprovince = o.hiercode
> AND o.del = 0
> AND o.level = 2
> LEFT OUTER JOIN locations d
> ON m.destinationprovince = d.hiercode
> AND d.del = 0
> AND d.level = 2
> JOIN commodities c
> ON m.id = c.movementid
> AND c.del = 0
> AND c.commodity = 2
> LEFT OUTER JOIN species sp
> ON c.commodity = sp.id
> AND sp.del = 0
> LEFT OUTER JOIN reasons r
> ON c.purpose::int = r.id
> AND r.del = 0
> WHERE m.del = 0
> AND originprovince is not null
> AND originprovince not like '0'
> AND destinationprovince is not null
> AND destinationprovince not like '0'
> ) AS s
> WHERE s.origindate > '%start%'
> AND s.origindate < '%end%'
> ORDER BY s.origindate
> ) AS foo USING UNIQUE id USING srid=4326"
> TYPE LINE
> STATUS ON
> HEADER 'templates/trade_header.html'
> FOOTER 'templates/trade_footer.html'
> CLASSITEM commodity
> CLASS
> NAME "Buffalo"
> EXPRESSION "2"
> STYLE
> SYMBOL "arrow1"
> OFFSET 0 0
> SIZE 12
> COLOR 0 0 255
> END
> TEMPLATE 'templates/trade_query.html'
> END
> END
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome WA 6725
Out here, it pays to know...
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090628/d307e669/attachment.html
