[mapserver-users] Dynamic LabelItem
Steve Lime
Steve.Lime at dnr.state.mn.us
Tue Jun 30 11:28:30 EDT 2009
That particular portion of MapServer has undergone a lot of change. At first I removed too much
functionality in 5.0, then exposed a bit more in 5.2 and probably got a lot closer to "right" in 5.4.
You're safest with 5.4.1 if you can afford to upgrade. What version exactly are you using?
Steve
>>> On 6/29/2009 at 2:13 PM, in message <1246302809284-3176452.post at n2.nabble.com>,
stretch <andrew.deklerk at gmail.com> wrote:
> ok - thanks for the response. If I try
> &map.layer[Compartments]=labelitem%20Age
> i get
> getSymbol(): Symbol definition error. Parsing error near ():(line 1)
> I am using Mapserver 5, I guess I should be using 5.4?? If that is the case,
> is there a solution I could use with version 5 or will I need to upgrade
> Thanks
