[mapserver-users] Beginning mapserver & sql server 2008
Fawcett, David
David.Fawcett at state.mn.us
Tue Jun 30 14:04:16 EDT 2009
Unless you are including the layer name in the URL used to call
MapServer, you should change the layer status to DEFAULT.
David.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Wesley
Sent: Tuesday, June 30, 2009 12:08 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Beginning mapserver & sql server 2008
Hi all,
It's my first time with mapserver, and I'm trying to use a map file
connected with sql server 2008. Mapserver is generating a blank image. I
think there is something wrong with my map file below. Do you have any
examples or tutorial about it?
Thanks, __________________________________________________________
MAP
NAME "sample"
STATUS ON
SIZE 400 300
IMAGETYPE gif
EXTENT -66.00 -22.00 -44.00 -9.00
UNITS DD
# Start of web interface definition
WEB
TEMPLATE "D:\ms4w\Apache\htdocs\testesql.html"
IMAGEPATH "D:\ms4w\tmp\ms_tmp\"
IMAGEURL "/tmp/"
END
LAYER
NAME "Camada1"
CONNECTIONTYPE PLUGIN
PLUGIN "D:\ms4w\plugins\msplugin_mssql2008.dll"
CONNECTION
"server=luzon2\sqlexpress;uid=sa;pwd=senha1234;database=TESTE;Integrated
Security=false"
DATA "geom from lixo"
TYPE POLYGON
STATUS ON
PROJECTION
"init=epsg:4326"
END
CLASS
STYLE
COLOR 0 0 255
WIDTH 8
END
END
END
END
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
