[mapserver-users] compiling mapserv 5.4.1 with PNG driver
Peter Peterse
peter at peterse-uithuizen.com
Tue Jun 30 16:41:50 EDT 2009
Hello,
I'm trying to compile mapserv v5.4.1. I used the next configure command:
./configure --with-ogr=/usr/local/bin/gdal-config \
--with-gdal=/usr/local/bin/gdal-config \
--with-httpd=/usr/sbin/httpd \
--with-wfsclient \
--with-wmsclient \
--enable-debug \
--with-curl-config=/usr/local/bin/curl-config \
--with-proj=/usr/local \
--with-tiff \
--with-gd=/usr/local \
--with-jpeg=/usr/lib/ \
--with-png=/usr/local/bin/libpng12-config \
--with-freetype=/usr/ \
--with-threads \
--with-wcs \
--with-wfs \
--with-postgis=/usr/local/pgsql/bin/pg_config \
--with-libiconv=/usr \
--with-geos=/usr/local/bin/geos-config \
--with-xml2-config=/usr/bin/xml2-config \
--with-sos \
--with-agg=/home/peter/src/agg-2.5
after the make command there is a mapserv program.
mapserv -v gives:
MapServer version 5.4.1 OUTPUT=GIF OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG
SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
SUPPORTS=THREADS SUPPORTS=GEOS INPUT=TIFF INPUT=EPPL7 INPUT=POSTGIS
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
In my map-file I have defined OUTPUTFORMAT:
OUTPUTFORMAT
NAME agg
DRIVER AGG/PNG
IMAGEMODE RGB
FORMATOPTION "INTERLACE=false"
MIMETYPE "image/png"
END
this give the next error:
OUTPUTFORMAT clause references driver AGG/PNG, but this driver isn't
configured.
Does anyone knows what I'm doing wrong?
Thanks for your response.
Peter.
