[mapserver-users] 'errno: 2' on projection
kapilmanoj
kmanoj-pg7 at iiitmk.ac.in
Thu Mar 5 02:05:37 EST 2009
Hello wendall,
I too facing the same problem. have you got solution for this problem?
could you please help me out?
Thanks,
kapilmanoj
Wendell Turner wrote:
> On Mon, May 19, 2008 at 03:32:16PM -0700, Wendell Turner wrote:
>> I'm trying to use the 'projection' tag in a map file, but it
>> is not working, and would like help.
>> I'm using Fedora 7, and there is a mapserver 4.10 in a yum
>> repository, which pulls in proj as a dependency. However,
>> when using the 'projection' tag, it gets
>> msProcessProjection(): Projection library error. no system list, errno:
>> 2
>> (which seems to mean 'file not found')
> As it turns out, other projections work.
> I'm just trying to get the v4 tutorial working, which is
> where the problem occurs. Any example that contains
> PROJECTION
> "init=epsg:4326"
> END
> gets the error msg. However, the file
> /usr/local/share/proj/epsg contains an entry for 4326.
> Q: why doe the example in the tutorial not work?
> Q: how can it be fixed?
> Thanks,
> Wendell
> mapserver-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/%27errno%3A-2%27-on-projection-tp1970528p2427848.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
