[mapserver-users] confused about using zoomRectangle
Ahmet Temiz
temiz at deprem.gov.tr
Fri Mar 6 14:02:38 EST 2009
hi,
thank you
I had tried two ways you mentioned as 1 and 2
"1" is rectObj(10,10,100,100,0)
"2" is rectObj(10,100,100,10,0)
both resulted exception.
what I want to know is that if I can create any image box providing keeping the same size.
I mean rectOb(11,11,101,101) and rectOb(12,12,102,102) and so on have same effect
on zoomRectangle.
regards
On Fri, 6 Mar 2009 16:42:45 +0100, Tamas Szekeres wrote
> Hi,
> I guess you've run into the problem reported in
> http://trac.osgeo.org/mapserver/ticket/1988
> http://trac.osgeo.org/mapserver/ticket/1817
> and some other related tickets.
> I'm not sure why this issue haven't been addressed yet, seem you have to swap the miny and maxy values in the rectangle before passing to zoomRectangle right now.
> Best regards,
> Tamas
> 2009/3/6 Ahmet Temiz <temiz at deprem.gov.tr>
> hello
> I am using mapserver-java-mapscript.
> I am very confused about using zoomRectangle.
> I tried zoomRectangle in two ways. But I still have exception.
> here is the java code I tried and related exception results:
> 1..
> rectObj imgrect =new rectObj(10,10,100,100,0);
> map0.zoomRectangle(imgrect, 500, 500, map0.getExtent(), null);
> SEVERE: java.lang.UnknownError: mapscript::mapObj::zoomRectangle():
> General error message. image rectangle maxy >= miny
> javax.faces.el.EvaluationException: java.lang.UnknownError:
> 2..
> rectObj imgrect =new rectObj(10,100,100,10,0);
> SEVERE: java.lang.UnknownError: rectObj():
> Invalid rectangle. { 'minx': 10.000000 , 'miny': 100.000000 , 'maxx':
> 100.000000 , 'maxy': 10.000000 }
> javax.faces.el.EvaluationException: java.lang.UnknownError: rectObj():
> I will appreciate, if you give your sense.
> regards
> Open WebMail Project (http://openwebmail.org)
> This message has been scanned for viruses and
> dangerous content by MailScanner, and is
> believed to be clean.
> mapserver-users at lists.osgeo.org
> dangerous content byMailScanner, and is
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090306/2acc3ea6/attachment.html
