[mapserver-users] Problems mapping regions that span Dateline
Roger André
randre at gmail.com
Fri Mar 6 17:53:31 EST 2009
Hi Brent,
Thanks for your reply. Converting to a 0 - 360 longitude span seems
like it would work, but as part of my map contains imagery data, I
think it would probably be best if I could define a new projection in
my epsg file that contained the required parameters. Is that
possible? I have implemented the DateLine wrap in OpenLayers, and it
works well there. Unfortunately, I also need to generate some map
images dynamically via mapscript, and this is where I have the most
problems.
Thanks again,
Roger
On Thu, Mar 5, 2009 at 1:54 PM, Brent Wood <pcreso at yahoo.com> wrote:
> Welcome to my world...
> The simplest way is, if you can, convert your longitutes to a 0-360 instead of +-180 space. If you use PostGIS the shift_longitude function works, Proj.4 can also be told which space to use for western hemisphere longitudes and generate longs in the 0-360 space.
> Alternatively, if you stick to +-180, you can use OpenLayers at the client end, as this has a switch available to work across 180.
> HTH,
> Brent Wood
> --- On Fri, 3/6/09, Roger André <randre at gmail.com> wrote:
>> From: Roger André <randre at gmail.com>
>> Subject: [mapserver-users] Problems mapping regions that span Dateline
>> To: "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
>> Date: Friday, March 6, 2009, 8:30 AM
>> Hi All,
>> I'm having some problems mapping some regions of the
>> world that span
>> the Dateline. I have several examples of this, but using
>> one, the UN
>> subregion defined as being "South Pacific", as an
>> example illustrates
>> the problem nicely. This region has the following extents:
>> Corner Coordinates:
>> Upper Left (-180.0000000, 28.2333333)
>> Lower Left (-180.0000000, -29.0666667)
>> Upper Right ( 180.0000000, 28.2333333)
>> Lower Right ( 180.0000000, -29.0666667)
>> The map that is generated using these extents with EPSG
>> 4326 spans the
>> entire globe, and I'd like to find a way to show the
>> are in a more
>> concise fashion. I have the same problem with New Zealand,
>> and with
>> the full extents of the USA.
>> Hoping for some suggestions.
>> Thanks,
>> Roger
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
