[mapserver-users] NQuery problem
Subha Ramakrishnan
subha at gslab.com
Fri Mar 13 01:43:54 EDT 2009
I am also facing a similar problem. It doesn't throw an error but it
doesn't give me a result either.
My url looks like this :
http://localhost/cgi-bin/mapserv?MAP=abc.map&MODE=nquery&LAYERS=abc&imgext=8920506.9477+3496535.4213+8954750.736418456+3530779.2100573704&imgbox=657+209+686+239&imgxy=670+230
The extent given here is within the map extent.
Can you please tell me if there's some mistake here?
Thanks a lot.
Subha
Steve Lime wrote:
> Nquery doesn't require qstring validation. What does your URL look like?
> Steve
>>>> Rui Gomes <ruijgomes at gmail.com> 03/12/09 9:42 PM >>>
> I try to use the nquery function and i recived the follow error message:
> mapserv(): Web application error. Metadata qstring_validation_pattern
> is not set.
> To avoid this i insert in the mapfile the follow lines inr the layer i
> want to query:
> METADATA
> qstring_validation_pattern '.'
> END
> What this lines means. Why i have to put it?
> Thanks
