[mapserver-users] Problems with Google 900913 Projection and
WMS Layers
Daniel Morissette
dmorissette at mapgears.com
Wed Mar 18 13:26:21 EDT 2009
Bill Thoen wrote:
> However, this doesn't work with my MapServer:
> PROJECTION
> "init=epsg:900913"
> END
> and throws the error:
> "Projection library error. no options found in 'init' file "
> I've put the google projection record in /usr/share/proj/epsg, but
> MapServer doesn't seem to find it (although it has no trouble finding
> other projections.) Is there some sort of indexing or registering I've
> got to do on this file?
The message "no options found in 'init' file" relates to the
"init=epsg:900913" directive. It means that an init file (called "epsg"
in this case) was found in PROJ4's data directory, but the definition
for code 900913 was not found in it. There is no indexing required for
init files. You just need to follow the right syntax when adding new codes.
If you verified that the code for 900913 is present in your
/usr/share/proj/epsg file then the only explanation I can think of would
be that your MapServer/PROJ installation looks for and finds the epsg
file somewhere else on the system. For instance, if you compiled PROJ4
yourself without specifying an explicit prefix (--with-prefix), then by
default the local build will look in /usr/local/share/proj and not
/usr/share/proj.
Also, see of the variable PROJ_LIB is set in your web server environment
or in a CONFIG directive in the mapfile. If it is set then it points to
the directory where PRPJ4 will look for the epsg init file.
Finally, you could try renaming the /usr/share/proj/epsg file to
something else and see if the error message changes. If the init file is
not found then the error should turn to "Projection library error. no
system list" ... if you don't get that error after renaming the epsg
file then your mapserver is definitely not using the epsg file that you
thought.
Daniel
Daniel Morissette
http://www.mapgears.com/
