[mapserver-users] Run-time substitution
Steve Lime
Steve.Lime at dnr.state.mn.us
Wed Mar 18 14:01:52 EDT 2009
It's not (and won't be) supported. There may be other ways to structure things but
you'd need to tell the list a bit more about your setup.
Steve
>>> On 3/18/2009 at 12:58 PM, in message
<5b61c6c50903181058t1e90456gf70858e15eb57801 at mail.gmail.com>, Ian
<iansgis at gmail.com> wrote:
> Hello,
> I have ~50 layers/shapefiles that are the same datasets scaled to various
> values, used in OpenLayers. My map file for this data is quickly growing
> (3000+ lines) and I was hoping to use run-time substitution to reduce this,
> changing the LAYER NAME and DATA. I've read the documentation on run-time
> substitution which didn't mention LAYER NAME as being supported (other posts
> made it sound like it specifically was not supported), and which I would
> need to change for OpenLayers. I want to confirm that LAYER NAME is not
> supported in run-time substitution before I re-work everything. Thank you.
> Ian
