[mapserver-users] queryByAttribute in C# mapscript
Murty Maganti
MMaganti at oriongis.com
Tue Mar 24 11:07:31 EDT 2009
Hi
I am using queryByAttribute on a SDE layer with a simple expression,
'OBJECTID = 750'. The method returns MS_FAILURE, though it is valid
expression. I can run same query in ArcCatalog and get the result back.
What do I need to verify here. I usually I check that there is template
name defined and maxscaledenom is set to -1. What else I am missing.
This is what is logged by map server
[Mon Mar 23 18:02:25 2009].834000
msConnPoolRequest(Canlur,vmonp03,port:5154,dmtigdb,dmtigdb,password) ->
got 1D49DFF8
[Mon Mar 23 18:02:25 2009].834000 msSDELayerOpen(): Layer Canlur
specified version SDE.DEFAULT.
[Mon Mar 23 18:02:25 2009].834000 msSDEGetLayerInfo(): Looking for layer
by TESTGDB.CANLUR, SHAPE, vmonp03,port:5154,dmtigdb,dmtigdb,password
[Mon Mar 23 18:02:25 2009].834000 msSDEGetLayerId(): Matched layer to id
112.
[Mon Mar 23 18:02:25 2009].834000 Getting all column information in
msSDELayerInitItemInfo
[Mon Mar 23 18:02:25 2009].834000 msSDELayerInitItemInfo(): getting info
for OBJECTID
for CATEGORY
for SHAPE
for OID
[Mon Mar 23 18:02:35 2009].338000 getSymbol(): Symbol definition error.
Parsing error near (OBJECTID):(line 831)
[Mon Mar 23 18:02:35 2009].370000 msQueryByAttributes(): Search returned
no results. No matching record(s) found.
I used another field PARCELID, which is also numeric but still does not
work.
Thanks
Murty
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090324/c937bd4c/attachment.html
