[mapserver-users] WMS and transparent
bartvde at osgis.nl
bartvde at osgis.nl
Wed Mar 25 10:52:14 EDT 2009
Yeah maybe OFFSITE can do this for you, give it a try, it works for normal
rasters so why not for a WMS client layer (haven't tried though).
Best regards,
Bart
> Thanks for the reply. I was hoping maybe MapServer could consume that
> jpeg and set the white color to transparent, then mapserver would output
> a PNG that has transparency to the web client. Does the offsite
> parameter do this by chance or is there another trick that could be
> used?
> -----Original Message-----
> From: bartvde at osgis.nl [mailto:bartvde at osgis.nl]
> Sent: Wednesday, March 25, 2009 9:47 AM
> To: Fischer, Brian
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] WMS and transparent
> Hi,
> jpegs can not be transparent. Only if you switch to another image format
> like image/png.
> Best regards,
> Bart
>> I am trying to consume this WMS service with MapServer 5.0.2 as a
>> client and would like to make the background transparent instead of
>> white. Is this possible mapserver? I tried the "wms_transparent"
>> "true", but that didn't seem to work. Thanks for any suggestions.
>> NAME '2003orthos'
>> STATUS ON
>> EXTENT 366751.468 5034450.028 882880.091 5434570.553
>> UNITS Meters
>> SIZE 600 400
>> FONTSET '../fonts/fontset.list'
>> SYMBOLSET '../symbols/symbol.sym'
>> IMAGETYPE PNG24
>> TRANSPARENT TRUE
>> WEB
>> IMAGEURL "E:\ms4w\tmp\ms_tmp"
>> IMAGEPATH "E:\ms4w\tmp\ms_tmp"
>> END
>> LAYER
>> NAME ND03
>> TYPE RASTER
>> OFFSITE 0 0 0
>> STATUS DEFAULT
>> CONNECTIONTYPE WMS
>> CONNECTION
> "http://web.apps.state.nd.us/wmsconnector/com.esri.wms.Esrimap/NDWMS_aer
>> ialimages?"
>> #MINSCALE 1000 # only display down to this scale
>> #MAXSCALE 24000
>> METADATA
>> "wms_srs" "EPSG:26914"
>> "wms_name" "ND03"
>> "wms_server_version" "1.1.1"
>> "wms_format" "image/jpeg"
>> "wms_styles" ""
>> "wms_exceptions" "application/vnd.ogc.se_inimage"
>> END
>> END
>> END
>> End #Map
>> Thanks,
>> Brian
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
