[mapserver-users] WFS Layer running OGR Query Multiple times per
request
joncoign
jncoign at Knology.net
Tue Mar 31 20:25:21 EDT 2009
I have a WFS layer that is querying the database via an OGR ODBC connection once per point included in the result set plus one additional query. I was under the impression that this should only execute once. Am I misunderstanding or do I have something misconfigured? Map file and SQL Profiler output below.
Map File
NAME "DevWFS"
CONFIG "PROJ_LIB" "F:\MapServer\Maps\Proj"
#CONFIG "MS_ERRORFILE" "F:\MapServer\Logs\MapServerLog.txt"
#DEBUG 5
PROJECTION
"init=EPSG:4326"
END
WEB
METADATA
wfs_title "UAI WFS Server"
wfs_onlineresource "http://localhost/cgi-bin/mapserv.exe?"
wfs_srs "EPSG:4326"
END
END
LAYER
NAME "SQL"
CONNECTIONTYPE OGR
CONNECTION "<OGRVRTDataSource>
<OGRVRTLayer name='SQL'>
<SrcDataSource>ODBC:Maps,JNCTest</SrcDataSource>
<SrcSQL>
EXEC dbo.MappingGetJNCTest %BBOX%
</SrcSQL>
<FID>ID</FID>
<GeometryType>wkbPoint</GeometryType>
<GeometryField encoding='WKB' field='the_geom' />
</OGRVRTLayer>
</OGRVRTDataSource>"
DATA "SQL"
DUMP TRUE
STATUS ON
#PROCESSING "CLOSE_CONNECTION=DEFER"
TYPE point
METADATA
wfs_extent "-180 -90 180 90"
gml_featureid "ID"
gml_include_items "all"
gml_exclude_items "the_geom"
END
END
SQL Profiler Output (3 Points match query)
exec [sys].sp_pkeys N'JNCTest',N'',N''
go
exec [sys].sp_pkeys N' ',N'',NULL
go
exec [sys].sp_columns_100 N'JNCTest',NULL,NULL,NULL, at fUsePattern=1
go
EXEC dbo.MappingGetJNCTest -67.64596191401315,17.434709503474547,-65.17403808598685,18.99999999999999
go
go
go
go
go
go
go
View this message in context: http://n2.nabble.com/WFS-Layer-running-OGR-Query-Multiple-times-per-request-tp2566330p2566330.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
